TA的每日心情 | 开心 2022-8-5 15:55 |
签到天数: 11 天 [LV.3]偶尔看看II
本帖最后由 Heaven_1 于 2022-10-18 14:00 编辑 2 r& `& e4 t: Q' f2 C: z% p: q
9 ^. ?, s* {. V7 a1 Features
% [ c+ Z! T3 W. c6 mMultiple Device Access (MDA):) D0 N+ s( Z4 `1 R# P/ _
Global Read/Write Operations
\# \' q9 R0 T$ j4 XI2C™ and SMBus™-Compatible InteRFace
1 [$ ~8 x: q. H0 mResolution: 8 Bits: A/ e1 e; b' N2 E7 v" N% U g' Z
3 Description6 m8 U9 A% |2 m( x
The ZCC103 is a digital output temperature sensor in
% M2 ?. K2 Z8 G- L: [a four-ball wafer chip-scale package (WCSP). The
' B ? B! ?( b+ P3 RZCC103 is capable of reading temperatures to a) G; Y1 t# F2 x' t( g" D
resolution of 1°C.5 ~. J: D, u" n; p& Q; X6 K
The ZCC103 features a two-wire interface that is# Q, ?! F. G. |; n
compatible with both I2C and SMBus interfaces. In4 Q' u1 F4 F, F. A- ]
addition, the interface supports multiple device9 J) _, L+ a$ g: V) v3 d3 n6 r# @
access (MDA) commands that allow the master to
8 a" s ~5 q9 W% fcommunicate with multiple devices on the bus
: F" h( }& W. v- V1 @) c- H3 xsimultaneously, eliminating the need to send$ d4 N( j6 h' q" W8 [
individual commands to each ZCC103 on the bus.
( Y3 s: e6 o5 y) E0 j' sUp to eight ZCC103s can be tied together in parallel
' M# s# Q5 \# H" gand easily read by the host. The ZCC103 is
1 i# b/ T( ^- @& c& Mespecially suitable for space-constrained, power-
$ `2 c& B4 E) vsensitive applications with multiple temperature
) B- S4 P d! F9 m& o# x& e+ p" @( Vmeasurement zones that must be monitored.
& d( h; H U! H, O4 H+ \8 mThe ZCC103 is specified for operation over a6 f' a# n4 q9 i! U
temperature range of –40°C to 125°C w% x) r% @7 \- x
.Device Information(1)' g4 W7 F; q/ `/ Z
Accuracy: ±1°C Typical (–10°C to 100°C)
! X* K9 r4 `( N7 zLow Quiescent Current:
$ X& v8 R- ~8 V w# u4 Y# z- j3-μAActiveIQ at0.25Hz
) Q) Z4 U5 n5 m7 V" s1-μA Shutdown* D: e: r4 \# R9 j4 F
Supply Range: 1.4 V to 3.6 V% g3 W T$ }$ ~
Digital Output0 P7 g+ O" v& P, j7 u# O# V" e
