, }, }- W$ `: u- CERROR: Techfile conversion failed!" A& E! k) t. N) n/ V! _5 B4 h
WARNING: layer TOP not found in layer table. Check the Allegro cross-section!: r1 {( @) V5 E/ J0 z* k, K
WARNING: layer BOTTOM not found in layer table. Check the Allegro cross-section!, a1 @: k4 D5 ?( N1 |) W1 k
WARNING: layer ART04 not found in layer table. Check the Allegro cross-section!
( Q: v9 A- `) u& a% xWARNING: layer POWER05 not found in layer table. Check the Allegro cross-section!$ X( l* s: g; b! m# n: |9 [) h
WARNING: layer ART03 not found in layer table. Check the Allegro cross-section!0 ^. y, |2 o1 \( u4 G8 [
WARNING: layer GND02 not found in layer table. Check the Allegro cross-section!! H: ]/ {( T/ Y& }' z+ M
ERROR: no data issued for clearance DEFAULT5 |) y) q; q' q) ?3 q1 Z
WARNING: layer SOLDERMASK_TOP not found in layer table. Check the Allegro cross-section!
3 q9 ^6 ]' `( M- I! J E+ |3 J( K) sWARNING: layer SOLDERMASK_BOTTOM not found in layer table. Check the Allegro cross-section!
' u/ f4 Y0 D3 \, Y: p. J% U8 qWARNING: layer PASTEMASK_TOP not found in layer table. Check the Allegro cross-section!
) U) k3 U. ~# _3 r6 C6 {WARNING: layer PASTEMASK_BOTTOM not found in layer table. Check the Allegro cross-section!
* S& D2 n- X+ C( @% D' nWARNING: layer FILMMASKTOP not found in layer table. Check the Allegro cross-section!% E+ f# t |2 Q& p) L
WARNING: layer FILMMASKBOTTOM not found in layer table. Check the Allegro cross-section!
/ j$ u- ~$ W4 TERROR: Unable to issue shapes for padstack BALL14M2 - layer problems6 H/ N( e* k+ X: a
ERROR: Unable to issue shapes for padstack BALL10M1_5 - layer problems
* N9 ~3 u* i/ e1 w7 g- W* BERROR: Unable to issue shapes for padstack BALL40M20PN - layer problems
. p/ J( O4 c2 ~1 S+ K1 pERROR: Unable to issue shapes for padstack RECT10X60 - layer problems1 W6 Y( V& J/ |
ERROR: Unable to issue shapes for padstack SMD_SQ12M2 - layer problems
' D0 I6 z* Q' @$ H7 [, I5 Z* X, ZERROR: Unable to issue shapes for padstack RECT103X138PN - layer problems
, P3 z: S% n$ }3 q* ]/ _ERROR: Unable to issue shapes for padstack SMD_OV63X24 - layer problems
( k6 }; F3 @1 p4 Y5 HERROR: Unable to issue shapes for padstack SMD_OV12X36M2 - layer problems2 ^( Y: g& Y8 }4 Z" l: O: r9 u; d
ERROR: Unable to issue shapes for padstack RECT25X70 - layer problems L- Y2 J- I6 O T( ~$ L, S* t
ERROR: Unable to issue shapes for padstack RECT24X60 - layer problems
# Y4 }1 {- B( Q/ c3 ]& [ERROR: Unable to issue shapes for padstack SMD_OV24X74 - layer problems) A* W7 l& Y) C
ERROR: Unable to issue shapes for padstack SMD_OV24X52 - layer problems5 ?* c: X+ E3 k1 _2 J) G
ERROR: Unable to issue shapes for padstack SMD_RE47X55 - layer problems
7 Q0 ^* L3 B" ?- t' ^# y2 v' R. D( X0 x! L
----我的出这种错误,请问你们的问题解决了么?1 R H; K2 S; B J# s' B( }. c
6 T1 ~6 Y, j* Q/ ^# H
