查看: 1199|回复: 5
导入logic时出现问题,请帮忙看看
发表于 2012-2-21 10:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
导入logic时,出现如下警告,不知道是什么地方设置有问题,请帮帮看看,谢谢。% V" \; X1 o" b1 r* ^9 {1 r1 Z
, g7 O5 s9 U6 b: Y#1   WARNING(304) Device/Symbol check warning detected.7 y1 v: l0 s& O5 \7 R
5 i2 x3 ~9 ]) N7 mUnable to load symbol 'C0402_0P55' for device 'CAP_C0402_0P55_100PF_NPO_50V': Couldn't find padstack: OB20X25
9 s3 F! `) t5 \+ P. F, ?( x3 z. z$ q2 r9 m0 h" l
#2   WARNING(304) Device/Symbol check warning detected.; a! ?; `4 N( u! W% L! y- G
- ^; M, j0 k0 Y0 F" k# eUnable to load symbol 'C0402_0P55' for device 'CAP_C0402_0P55_100NF_Y5V_10V': Couldn't find padstack: OB20X252 E4 ~: Q4 x: g/ e% D2 {
7 k5 `8 i2 O  z1 T  n#3   WARNING(304) Device/Symbol check warning detected.
" G" P- n. k% P0 E7 v$ a7 s
; q9 @& J9 U# v- OUnable to load symbol 'MLVS_0603_0P9' for device 'MLVS0603M04_MLVS_0603_0P9_MLVS0': Couldn't find padstack: OB29X37. S. Q, V2 m7 |9 |* c/ i6 o
5 p, F# R0 b2 O+ ?
#4   WARNING(304) Device/Symbol check warning detected.$ L: }9 q: @# L
, u6 u7 N. O9 J( Y# R( yUnable to load symbol 'CON_8PIN_0P5_1-8' for device 'POWER_BOARD_1_CON_8PIN_0P5_1-8_': Couldn't find padstack: R12X598 V1 L8 J6 N0 `" }( N: d- n
+ j/ h, d$ v4 D
#5   WARNING(304) Device/Symbol check warning detected., M/ [9 Y/ X" k6 X5 h% l2 R9 ~- t& ]* U
: y- Y* N# F) K2 B7 S9 Q7 kUnable to load symbol 'LED0603_0P4' for device 'SMD_LED_0_LED0603_0P4_LED_WHITE': Couldn't find padstack: OB32X35
& I$ @2 O7 |6 Z' o& W3 ^; s
1 N% o* r% i  {. A: Z3 @3 j  X3 j#6   WARNING(304) Device/Symbol check warning detected.
9 k( M) O- q, c/ S" }
' R8 c! Z5 U% V7 MUnable to load symbol 'DO_SOD323_1P7X1P25X1P1' for device 'PESD5V0L1BA_DO_SOD323_1P7X1P25X': Couldn't find padstack: OB25X33
9 x. P9 ^& i5 @, m1 g5 o3 Q0 B9 I+ ~/ W" b1 B8 Q; V
#7   WARNING(304) Device/Symbol check warning detected.# _$ i  o. E  G5 u4 y. a- Z! o
3 I0 x4 t6 C( `- a/ G
Unable to load symbol 'R0402_0P4' for device 'RES_R0402_0P4_100K_5%': Couldn't find padstack: OB20X25
/ Z: j8 e" N0 Z8 T% U1 P4 t8 Z' Z* a  \* a/ B/ \
#8   WARNING(304) Device/Symbol check warning detected.
+ U$ m! w9 b6 \1 f+ V" g- y' V3 F. l- j$ ^# K. q
Unable to load symbol 'R0402_0P4' for device 'RES_R0402_0P4_1K_5%': Couldn't find padstack: OB20X25' s+ \% F) q8 `& n& w
% M& p& [& A( Z( W8 f4 a- M1 `
#9   WARNING(304) Device/Symbol check warning detected.' v) y. c/ N% ~
$ Q6 I1 G. n& U; u4 ?  S& h3 C
Unable to load symbol 'SW_TACT_STS-05-A_1P7' for device 'STS-05-A_SW_TACT_STS-05-A_1P7_S': Couldn't find padstack: OB24X40  ~9 h! z6 z* A1 |% o+ [
: e* t" g3 h' e4 ^#10  WARNING(304) Device/Symbol check warning detected.& I  _0 b  K' X6 ~7 J- T3 m
  p2 u# ~9 J- n% w. ?Unable to load symbol 'SOT23_2P9X1P6X1P45_1P9' for device 'APX9131_SOT23_2P9X1P6X1P45_1P9_': Couldn't find padstack: OB24X36
+ Z+ \6 S! K) `- h( ^) X& M7 @/ p
0 l  A- d8 h8 ], n4 x* `9 u5 B------ Library Paths ------) j; c. B8 t" Z$ H, \0 F0 q9 r
MODULEPATH =  .   n1 G2 ]6 d2 y2 k
           C:/cadence/SPB_15.7/share/local/pcb/modules
* m: ^# R+ g- `7 v. r! k+ ^7 }8 P' Z* \/ Y
PSMPATH =  . " Q: `2 f+ J- T3 o% F' T
           symbols " N) ~# J. n$ r' K* y1 F! V* u
           .. ) M$ V0 V8 ^8 a/ B
           ../symbols
1 k9 j) o' z- _           C:/Cadence/SPB_15.7/share/local/pcb/symbols 3 x7 O7 _6 r% \3 h$ q( u
           C:/Cadence/SPB_15.7/share/pcb/pcb_lib/symbols
2 o% F* @, H' h& @% k4 g! J4 g           C:/Cadence/SPB_15.7/share/pcb/allegrolib/symbols
$ s0 ^3 {& R6 T1 L           C:\Users\EMC\Desktop\sophia2011\PTC3.0\CIS_Library_0907\   q5 O8 ]: Z: Q( G
           C:\Users\EMC\Desktop\sophia2011\PTC3.0\CIS_Library_0907\CIS_Library_0907\Connector\ . u  @$ B& O1 C5 ]* A) \1 T. N
           C:\Users\EMC\Desktop\sophia2011\PTC3.0\CIS_Library_0907\CIS_Library_0907\DIP\
" Z. H- H1 A! F5 G' f7 m# R4 v           C:\Users\EMC\Desktop\sophia2011\PTC3.0\CIS_Library_0907\CIS_Library_0907\IC\
0 {! V; L3 l; F           C:\Users\EMC\Desktop\sophia2011\PTC3.0\CIS_Library_0907\CIS_Library_0907\ME_Symbol\
  l" `& d$ I- q) v; D           C:\Users\EMC\Desktop\sophia2011\PTC3.0\CIS_Library_0907\CIS_Library_0907\Mounting Hole\
4 Y4 v. Y9 z  z# ~6 X+ a           C:\Users\EMC\Desktop\sophia2011\PTC3.0\CIS_Library_0907\CIS_Library_0907\Pad\
; u! ~. S- K& a) ^           C:\Users\EMC\Desktop\sophia2011\PTC3.0\CIS_Library_0907\CIS_Library_0907\SMD\ ; a  X- |- S% E! |4 v0 H1 _
' Y/ C  ^, m8 \2 E/ {# }. XPADPATH =  . 3 _! J( f7 [" J' j
           symbols
" e) F  M7 u6 f           .. ! B% m4 H% E) L& I/ |
           ../symbols 5 [% j2 L$ N2 x) }  f
           C:/Cadence/SPB_15.7/share/local/pcb/padstacks 8 b. `) r* U7 j! k+ B9 r
& o2 }0 `9 W  @           C:/Cadence/SPB_15.7/share/pcb/allegrolib/symbols
7 S: K. i& H: {  U4 x           C:\Users\EMC\Desktop\sophia2011\PTC3.0\CIS_Library_0907\CIS_Library_0907\Connector\
  z  B! F0 O9 \           C:\Users\EMC\Desktop\sophia2011\PTC3.0\CIS_Library_0907\CIS_Library_0907\DIP\
+ d8 J& S7 P' c6 i- i
5 k2 ~  ]2 t9 `% X5 ?  J* r
0 p) z$ y2 _+ y  |------ Summary Statistics ------
2 q# R6 h3 h% ^! B# c7 ?
4 Z9 h; Q0 I3 U  B5 K" J0 m" S/ z
% y! B0 o! J2 g# v: J, {# x3 jnetrev run on Feb 21 9:58:03 20125 o3 k; P7 m+ v$ f) v$ L
   DESIGN NAME : 'POWER BOARD'
" k* N0 {& N4 d) G6 ~0 ?4 H   PACKAGING ON May 28 2006 22:05:31; P! n/ |* t: I8 W, r8 Y
3 n: F" q( b% p1 t) i   COMPILE 'logic'
# k  I7 r; }0 x3 }/ z1 s   CHECK_PIN_NAMES OFF' R) _1 `8 P& s& r9 |# _
   CROSS_REFERENCE OFF
+ `# y1 G: g( Z# ~   FEEDBACK OFF: S3 }1 L) f1 F& }
   INCREMENTAL OFF+ P7 K" b" a+ q
   INTERFACE_TYPE PHYSICAL
/ e, {2 Z# h: I) l2 H0 k# F   MAX_ERRORS 500; x5 n: x9 ?  b% @
   MERGE_MINIMUM 5" L6 X! r6 f: Y' u( C# b' a
   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'+ ?' |/ `# f& ~6 S! E+ F' j
   NET_NAME_LENGTH 24
/ k* s4 \3 O8 {, k5 {' p   OVERSIGHTS ON5 G' Z% h& t& e/ w' R/ n
   REPLACE_CHECK OFF
- i# F3 i/ p) X* G' _+ u   SINGLE_NODE_NETS ON
' ~* b! V3 o6 ^2 m( W2 _   SPLIT_MINIMUM 0# q' o- t  S$ K( i
   SUPPRESS   20
; c; u3 }; c4 r; J) ]' s   WARNINGS ON
* @* Q6 ^- U/ v3 C5 l0 C, L9 K9 g$ i. S6 U# D1 h/ S
No error detected
0 K# d  Z" C) U& s' D$ D! r No oversight detected+ }/ r8 {9 G" B: b+ N
10 warnings detected4 T  Q) @( W; v# H" z, u, d
: z: Q$ g$ U4 o- u  Acpu time      0:00:22
& J! b, g1 L( Kelapsed time  0:00:00
8 O  Z5 ^7 Q) V: T' p& }! H
7 J. a) `+ E8 k! i; u
    奋斗
    2022-7-27 15:32
  • 签到天数: 6 天
    [LV.2]偶尔看看I
    发表于 2012-2-21 10:50 | 只看该作者
    “Couldn't find padstack”核对下你的库对好了没
    发表于 2012-2-21 11:31 | 只看该作者
    Admin Locked Database{:soso_e100:}
     楼主| 发表于 2012-2-21 13:45 | 只看该作者
    hujzh888 发表于 2012-2-21 11:31
    / k# F; a  X# f: n. _Admin Locked Database
    , r4 n  C+ f1 j0 i
    不好意思能講詳細一些吧 謝謝
    发表于 2012-2-21 13:52 | 只看该作者
    yangfan0913 发表于 2012-2-21 13:45
    - _/ i* O3 b5 ^2 [% ]2 L. m, Y不好意思能講詳細一些吧 謝謝
    3 ~* {4 f$ e7 n5 g5 C: q呵呵,我发错了地。建议你按2#的说法检查你的元件库及库路径。{:soso_e100:}
     楼主| 发表于 2012-2-21 15:45 | 只看该作者
    hujzh888 发表于 2012-2-21 13:52
    7 @* o1 u5 e. _: K呵呵,我发错了地。建议你按2#的说法检查你的元件库及库路径。
    5 g: V; E  C% f2 p. M, Q2 d 我以前用得是16.3的  现在用15.7的 库文件需要更改吗?
    GMT+8, 2025-7-31 06:59 , Processed in 0.109375 second(s), 24 queries , Gzip On.
