查看: 996|回复: 0
LP_Wizard10.3.2 update1安装后,运行软件出现的问题
发表于 2012-2-22 10:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
LP_Wizard10.3.2 update1安装后,运行软件出现下面语句。) L& L% H! _. a# J! x& Z
unhandled exception has occurred in your application.if you click continue,the application
% [/ q% O& z4 r
2 N# N. Q/ }3 z5 S2 n8 awill ignore this error and attempt to continue.if your click quit,the application will $ [3 A- Z1 G: s
1 o9 L" ^; N  O
close immediately.
4 @8 E& Y! X: [5 @6 n3 a6 z9 ?) icould not load file or assembly 'system 8 a1 R' d' E- ^# Z# S
; K, D1 p- o! T3 C; x* icore,version=3.5.0.0,culture=neutral,publickeytoken=b77a5c561934e089' or one of its
, e4 z/ L6 {" ]; X3 R+ X: H
2 _+ j' j9 B( O: Ndependencies.the system cannot find the file specified
6 k2 y2 b) `" B2 n是电脑不行,还是缺少什么软件
GMT+8, 2025-7-31 06:52 , Processed in 0.109375 second(s), 24 queries , Gzip On.
