查看: 2947|回复: 4
救命啊~~~~~~~这么错误太无稽之还是本人太笨~~~
发表于 2012-2-22 19:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#1   ERROR(SPMHNI-191): Device/Symbol check error detected.
. }) v7 Q- S; j5 k/ H) F/ }
7 s3 e; P/ h4 l9 Q" p9 ]ERROR(SPMHNI-195): Symbol 'CAP0603' for device 'BNC_CAP0603_AUDIO IN2' is missing pin '3'.4 L- }6 j) a1 N  T: m1 t
7 ^% A. `/ s7 R% p1 V
ERROR(SPMHNI-195): Symbol 'CAP0603' for device 'BNC_CAP0603_AUDIO IN2' is missing pin '4'.
  L7 U, y3 {/ h! @, G
: k+ i7 c% _1 C7 f$ mERROR(SPMHNI-195): Symbol 'CAP0603' for device 'BNC_CAP0603_AUDIO IN2' is missing pin '5'.  @  _& P# V' l, T3 @
: {- d' Q# V8 ~, i, C  S  J
#15  WARNING(SPMHNI-192): Device/Symbol check warning detected.$ Z8 C' Z: J0 ~& X; k. h; K4 {
7 V- X9 N2 x4 `WARNING(SPMHNI-337): Unable to load symbol 'MOLEX-67491-002' for device 'SATA-FEMALE_MOLEX-67491-002_WAT': WARNING(SPMHUT-127): Could not find padstack 42X60RD29.% E) G% H& |1 o3 q, u. f* ?1 @
5 C# {  f1 D' q# q9 g1 j& l4 ]
#16  WARNING(SPMHNI-192): Device/Symbol check warning detected.3 T& p3 k4 Y8 S% p- J
" s6 D+ s( Y' b7 i; EERROR(SPMHNI-196): Symbol 'ND151' for device 'DIODE SCHOTTKY_ND151_ND151' has extra pin 'C'.: `. h) D: z3 \
% u# N$ S: j) s3 h, f  G
ERROR(SPMHNI-196): Symbol 'ND151' for device 'DIODE SCHOTTKY_ND151_ND151' has extra pin 'A'.# A. Q( N9 f! m9 E1 f
& P7 ]$ R4 b2 V' |9 p7 bERROR(SPMHNI-195): Symbol 'ND151' for device 'DIODE SCHOTTKY_ND151_ND151' is missing pin '1'.
, {0 T( m6 A$ M) V
% P9 H( T, ^2 Y) nERROR(SPMHNI-195): Symbol 'ND151' for device 'DIODE SCHOTTKY_ND151_ND151' is missing pin '2'.
* S: ]% A5 ^& e5 z$ C
9 e' e. ~; n: D! P! y% y) g' ^6 i  X- }5 L3 O
上面两个错误,一个是电容,一个是二极管,都是只有两只脚,也就是pin1 pin2,为什么会这样提示,本人入门新手,已经保证了原理图和封装都只是两pin,求解!!急!~!~!
发表于 2012-2-22 22:44 | 只看该作者
检查下器件编号吧,是不是弄混了
    擦汗
    2024-5-15 15:49
  • 签到天数: 314 天
    [LV.8]以坛为家I
    发表于 2012-2-22 23:32 | 只看该作者
    1、Symbol 'CAP0603' for device 'BNC_CAP0603_AUDIO IN2' is missing pin '3'.)
    0 U. j4 E; ?; K; E7 }' b' q2 x" d- L
    CAP0603 封装没有3/4/5 pin,但是原理图中的封装有,检查原理图。
    " I$ a1 y- u' Z
    & J# ]0 G: P/ L- G$ Q$ d. x2、Could not find padstack 42X60RD29
    ; F+ `: C( t; ]' w9 J
    6 C' V  k, d0 W+ i% z9 k" g* C找不到焊盘42X60RD29,检查焊盘的路径。7 ?3 {. b5 c; \: a( S
    ! G# M0 d! ]* g, ?9 ]; ^, q5 w
    3、Symbol 'ND151' for device 'DIODE SCHOTTKY_ND151_ND151' has extra pin 'C'
    6 o$ s, w, w6 [$ @6 L" o$ @8 q3 t/ v* T( D
    ND151封装中pin命名为A和C,但原理图中pin命名为1和2.
    发表于 2012-2-22 23:49 | 只看该作者
    原理图画好之后,要重新排列一下位号
     楼主| 发表于 2012-2-23 11:10 | 只看该作者
    多谢大家的热心,问题解决了~~~嗯,以后就泡这论坛了~一起学习一起提高
    GMT+8, 2025-8-1 02:41 , Processed in 0.109375 second(s), 24 queries , Gzip On.
