查看: 500|回复: 3
[仿真讨论] speed2000仿真DDR4时报警告导致仿真出不了结果
发表于 2022-12-9 11:54 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
用自己的项目仿真DDR4,前面设置好了仿真组别模型,报以下警告怎么办。我查看信号并没有短路等这些问题,而且已经打板了。
& R4 i. s8 F$ j
/ b& D( T9 X' f, j: n7 e7 p. N3 G/ w$ N4 V% R5 b2 |
[2022/12/09-11:46:01]--Environment: Mesh on.' s* t$ k+ v2 D
[2022/12/09-11:46:02]--
4 X! M* U0 N/ Y7 r                       ****Signal Net Statistics for Net LPDDR4_DM0_A****** Q! ]& c5 O. l: ~; i
                        Total number of traces buried under pads :  1" b) x( c8 }  f3 w( h) O
8 {5 Q" _. `# E                       ****Signal Net Statistics for Net LPDDR4_CLKP_A*****
: n; V6 ?2 t3 w, N2 P5 `5 `                        Total number of traces buried under pads :  3
  I! B3 ?. u% r8 @5 c6 l' x3 S  ]- U  v[2022/12/09-11:46:02]--
5 h* {8 b. K# F' |9 w                       ****Signal Net Statistics for Net LPDDR4_CLKN_A*****( s' K& {# N  ~- @- ^( `) z0 n
                        Total number of traces buried under pads :  1* j; s0 |! |. C0 }4 j
/ e* v, V5 |; N, A                       ****Signal Net Statistics for Net LPDDR4_CKE0_A*****
4 f5 D5 p$ p7 i* I& v4 H( A# R9 L                        Total number of traces buried under pads :  2
; {! A- \9 W; K* W; w1 P[2022/12/09-11:46:02]--* H& S  A$ X7 }  j# U
                       ****Signal Net Statistics for Net LPDDR4_DQ2_B*****
/ K5 P4 N! W3 }$ ?/ _) E! l. q5 p: a- f                        Total number of traces buried under pads :  2
% V% \2 E( C& o4 l" D[2022/12/09-11:46:02]--+ i  V8 j; o/ Z# K8 Y7 e
                       ****Signal Net Statistics for Net LPDDR4_DQS0P_A*****6 ~4 h; R2 |2 t0 _
                        Total number of traces buried under pads :  3- W' U6 Z" s) I( B. d+ d
- Y' |* o5 b* G6 X/ a                       ****Signal Net Statistics for Net LPDDR4_DQ3_B*****4 B& _8 Q: v5 A9 w- F$ \
4 L3 Y, v! k: K[2022/12/09-11:46:02]--
1 f3 g* z  f. H                       ****Summary : Signal Net Statistics for the Design*****8 R1 A1 Y/ A& y) I7 G# F
                        Total number of small shapes :  0- e4 W" O( v2 x$ d9 J' n% S) k' b
                        Total number of large shapes :  0
  `5 l  K6 k* A5 G( l$ p                        Total number of traces buried under traces :  0% ~, y9 b7 x* G% F7 z
                        Total number of traces buried under pads :  15$ T  F$ C5 q3 r5 h* R
                        Total number of traces overlapping along length :  0
& l: ~: @' ~5 K2 P" z# x( o/ L% Z                        Total number of traces aligned along length :  0  p' h# @6 D. e1 Y
                        Total number of traces with no reference :  0; r5 f1 [) \+ I/ D
& Y" p+ a. P' ]7 T                       ****Summary: Miscellaneous check, Error(s) = 0, Warning(s) = 70
" W9 s% d! j" C9 g9 }2 l+ L" \[2022/12/09-11:46:02]--
6 }( S# L3 ]! ^                       ****Summary: Variables checks, Error(s) = 0, Warning(s) = 32
1 r8 x5 m3 ^& b9 ~" F8 ?, ?& O. O  v6 s2 P- [) b! A! \
1 k) I! n1 T2 F& S
    2022-1-29 15:04
    发表于 2022-12-9 13:35 | 只看该作者
    检查一下Probe探针的命名是否规范
    我就设置了这些,好像没有看到探针选项  详情 回复 发表于 2022-12-9 16:59
     楼主| 发表于 2022-12-9 16:59 | 只看该作者
    unfaithful2021 发表于 2022-12-9 13:356 q. g1 ?7 C7 ~+ H2 X5 S
    检查一下Probe探针的命名是否规范
    # r+ }- ~: D# U0 [. k/ F
    我就设置了这些,好像没有看到探针选项- |% V$ X- D9 S% J  Q8 x2 N1 Z
    3 b# x, A7 P2 Z- Z+ t" e4 q
    发表于 2022-12-26 17:49 | 只看该作者
    学习学习学习
    GMT+8, 2025-11-1 04:18 , Processed in 0.140625 second(s), 27 queries , Gzip On.
