查看: 2118|回复: 5
高手求助,急!!!
    擦汗
    2020-5-6 15:09
    发表于 2012-4-24 09:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    15.5.1版本
    ( K1 I1 i: @1 o网表导入allegro时出现如下警告:
    * A; ^! I5 v3 A( t1 _---------------------------------------------------------------------------------------------' K: `. E8 M9 l  }* j
    #1   WARNING(301) Device library warning detected.
    6 i) e3 m6 D. S6 w8 j
    + F: X  e, ]: m$ S5 R) JPin 'M_RCOMP2' for component 'CLV_0P51_BGA760' has no other swappable pins. Swapping ignored.
    0 X& r6 j* O. E- o$ X" |$ U9 b
    * W1 d5 l. ]( h  n#2   WARNING(301) Device library warning detected.3 K7 _: P% S" j8 |
    - y' r; g4 v/ g
    Pin 'RESETOUT#' for component 'CLV_0P51_BGA760' has no other swappable pins. Swapping ignored.
    # J& O0 E4 R3 u- B# s! s  q4 L! `
    ! [% s$ W0 I& s#3   WARNING(301) Device library warning detected.& {4 [8 S+ b5 z2 u3 c+ U# p$ o
    3 f3 D# y6 v. s/ sPin 'VCC180AON[3]' for component 'CLV_0P51_BGA760' has no other swappable pins. Swapping ignored.! n/ S* |. _' D5 U3 J0 \3 D) m* A
    ( |8 g1 _6 R' x* t( n9 ?" z
    #4   WARNING(301) Device library warning detected.+ H6 {* d  S, y9 _* s+ g
    1 u2 B5 u& [! O* p% L2 z' k
    Pin 'VCC330' for component 'CLV_0P51_BGA760' has no other swappable pins. Swapping ignored.. T( w8 H: p$ y( w
    5 Y; j2 d/ O- w6 X5 W; N7 S6 F4 f#5   WARNING(301) Device library warning detected.) F7 }' f2 L( F9 h8 d
    3 o9 O, G2 |1 y2 S' C1 A8 x
    Pin 'VNNAON[0]' for component 'CLV_0P51_BGA760' has no other swappable pins. Swapping ignored.  x& v8 r6 Z4 L$ Y6 T* |
    $ N/ k0 U) b$ P2 L% G
    #6   WARNING(304) Device/Symbol check warning detected.
    2 q2 \  B9 q; p) n3 y  T
    2 C; t2 M( S) U--------------------------------------------------------------------------------------9 O3 ?( H4 p7 b& ]8 x* q7 [
    'CLV_0P51_BGA760' 是CPU的封装,但是可以从库里调出来,看不出有什么问题,就是还有提示警告,怕怕的,哪位大侠帮小弟看看,是什么原因。原理图是从16.3转到低版本的,我现在用15.5.1版本; y7 V( }9 }5 q5 r* A4 |
    发表于 2012-4-24 10:33 | 只看该作者
    可以忽略,你的封装是拷贝别人的吧。没有把swap pin的信息也带进来。5 ~: W/ B. @8 M
    擦汗
    2020-5-6 15:09
     楼主| 发表于 2012-4-24 11:56 | 只看该作者
    封装是INTEL直接提供的,谢谢了!
    发表于 2012-10-29 10:31 | 只看该作者
    # r3 t1 F# e5 A2 W  M
    8 ?2 a  K  ~; K3 S* Gswappable pins是用于在PCB布局时掉换相同功能的引脚。可在原理图中把需要换pin的器件的可互换pin设为一组。
    6 W* g8 t' W8 m3 P% a4 p5 N$ F如果不设为一组,必须删除其值,不然就会报错。
    / N$ g; r. Y# G  k, U6 z$ I! w- q在orcad原理图中选中元件右键->Edit Part
    # V5 _! Y: ]( o) [# C+ i6 G8 kView->Package  然后 Edit Properties 找到 Pin Group 将想要换的pin设成同一个组,比如1,或者删除该值。& U9 v# f5 c8 N/ {' X
    Update 原理图,然后重新导入网表就OK了。
    发表于 2012-10-29 11:14 | 只看该作者
    你要把error的部分给拷贝上来。
    发表于 2012-10-29 11:17 | 只看该作者
    大家才能帮你解决哦。
    GMT+8, 2025-8-20 17:39 , Processed in 0.109375 second(s), 23 queries , Gzip On.
