查看: 4282|回复: 3
求助输出钻孔文件出错,谷歌翻译是说缺少钻孔数据,内有说明
发表于 2012-5-23 17:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
NC DRILL Log                                                     )
* @/ K+ f1 p7 R% h6 {& Q# A(        ). Q2 f% F. m) s" Q5 @! V
(    Drawing          : HopeREV1.brd                                  )
" y" |- T% a2 N7 j, `. {- m(    Software Version : 16.5S021                                      )- Y8 P+ Z4 a+ |9 f
(    Date/Time        : Wed May 23 17:13:15 2012                      )7 j8 @$ }8 l0 s
1 i' h1 {/ _. n& h* [8 \, u) [(---------------------------------------------------------------------)
  ~' j( w: c3 I6 w' I/ k' _/ u' r+ G, d/ t& O
! i. f6 [; l- U. {* P
8 x: ~3 _! ]9 O/ Z7 `2 k
Processing NC Parameters file ...! r. w( I4 o! G, X* X2 b% r
9 V4 y. c; J( _" l) ^5 l( [ NC PARAMETERS- N: M7 i' I7 t  V- N1 A( S
% V! t, m) \8 h- _. ]
, H7 U8 k* s6 e0 r. o FORMAT                   2.3: u+ w5 R% v9 i, H- b! ]9 r% x
MACHINE-OFFSET                x:0.000000        y:0.000000( V$ ~# j: ~( E3 A5 o
FEEDRATE                1; g  i  m8 Y0 W0 I* P6 l+ v" ^$ t
COORDINATES                ABSOLUTE. E( K3 u1 O9 z+ G& q
OUTPUT-UNITS                METRIC4 n3 p) i7 x2 F/ P) |9 g
TOOL-ORDER                INCREASING
- ^$ p( Y. c, i0 |  w. H" f& t REPEAT-CODES                YES
( {7 R8 ^& t- B SUPPRESS-LEAD-ZEROES        NO
+ b" j$ H# {( W$ |- G SUPPRESS-TRAIL-ZEROES        NO
' i7 i! ]% K: Z. X& B: q% d  s8 J SUPPRESS-EQUAL                NO& c: u; X) @& f3 u! v) a. G, _
TOOL-SELECT                NO
7 W4 l6 i! Q5 L/ ~: S9 i" Q+ A. Q& J HEADER                        none: r1 d9 D& s1 U  F
LEADER                        12. P. |7 c( b: P
CODE                        ASCII
( z: g' R2 A0 O, V' Y* c  g SEPARATE                YES
- ?, j2 l: p% Q8 o) z! h+ S, Y1 v OPTIMIZE_DRILLING        YES
3 y/ u' C$ L" { ENHANCED_EXCELLON        YES
2 Q5 Q; O3 z4 ^! s SCALE                        1.000000- G$ ~; @! ?+ b# j! v  C' p
% U( [" Q( q) N1 _
WARNING: Design precision is greater than that of the drill output file data.
2 a# S4 j: H7 l( h1 @$ y& R1 u          Data rounding errors are very possible.
( j  B  d5 K+ Q0 } ERROR: The number of integer places specified for the- A4 j* f6 l2 u4 V6 H) e  _
        drill output data is not enough for this design.0 w0 {+ ~9 H. [. }  O
发表于 2012-5-23 20:43 | 只看该作者
3 c+ }8 x# z2 M# F' Z! K  L
; q0 N0 T1 |  m4 t% k* D; t) Z设计精度比钻孔精度高& {' M# ~/ q1 e$ ?2 @" u
把钻孔的小数点多设几位就可以了
8 ^0 F+ b! `6 @$ g3 g" W就是前面的format2.3那里  改成5.5或者3.5应该就可以了- m6 W5 `+ _. s; r( \- f2 p
到底是谷歌翻译的不对还是你理解的不对啊
7 @6 N: D; z  i& y: z9 E: e/ b* q5 v! M- C$ E) u
( @- h3 t# `/ G" z$ W2 @' B# V
修正一下,这个提示应该是说gerber的整数位输出不够,估计你的) v4 V5 R3 N: z7 h: j1 |# k3 m
板子比较大,2位数不够标识。虽然我前面的改法应该对你有用,7 c' R2 ?5 V% a" _
但是原因表述不对。
发表于 2012-5-23 21:09 | 只看该作者
楼上正解
 楼主| 发表于 2012-5-24 09:59 | 只看该作者
amaryllis 发表于 2012-5-23 20:43 8 n' k3 n- h1 Z" I0 t( i
设计精度比钻孔精度高3 Q- w0 K7 h8 q- [; c8 @
把钻孔的小数点多设几位就可以了: W9 I1 G$ K& J, A. i1 h2 o9 X
就是前面的format2.3那里  改成5.5或者3.5应该就可 ...
2 K) Y4 f/ Y2 Y! ?2 U) Z* y谢谢~~~~~{:soso_e154:}
GMT+8, 2025-8-4 13:54 , Processed in 0.140625 second(s), 24 queries , Gzip On.
