#1 ERROR(310) Error detected saving layout file./ d$ v0 l& R c9 u( X
+ i& o1 W4 r6 G: X9 J6 g) bCannot write drawing, 'D:/Dev/Hardware-DEV/02DESIGN/0202Project/V2_0/RNS510_Base_V2_0/RNS510_BASE_V3_0.brd' out to the file system: 'Database has a non-recoverable corruption, contact cadence Customer Support.'.
+ O4 u- g7 H& u2 C/ W6 l; o
9 W# V1 p. c. Z: m6 o#2 ERROR(102) Run stopped because errors were detected& X% _; {2 w2 S7 C, ^
0 N) n$ R+ y( P: g% ~7 y
netrev run on Jul 3 13:59:33 20127 K m: A8 A, C% d; Q, w
DESIGN NAME : 'RNS510_MOTHERBOARD_V3_0'! w! m6 @$ n4 p' u; h, f$ A
PACKAGING ON May 28 2006 22:05:31
1 H" T) J5 M& U' x" P, L$ X
6 ~- d( T+ M( w% b+ z: T8 L COMPILE 'logic'
1 ~, Y( N+ P7 }" N6 N6 z CHECK_PIN_NAMES OFF. I" L, ~, r( d X S3 y) q
CROSS_REFERENCE OFF
8 \6 S' M+ e/ n1 `) B FEEDBACK OFF5 b& N* \: ~5 D5 M" P, r+ R2 a& X8 e. {
INCREMENTAL OFF, W' |9 y7 ~9 b$ u) n2 K I
INTERFACE_TYPE PHYSICAL
! |' k9 h; _# U MAX_ERRORS 500- r1 _; H7 A1 Y, g/ w3 g- \) ]3 J
MERGE_MINIMUM 59 v" |: [* Q. Z- y. X' L: p9 Y
NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'$ d8 w/ F. l+ h7 y8 D
NET_NAME_LENGTH 24
4 j- F3 `" x7 ]" ] OVERSIGHTS ON! D! y3 |" a2 a# a0 S/ b, Z& J4 g
REPLACE_CHECK OFF
/ E$ B M5 C- V( w8 U# r/ E& ^ SINGLE_NODE_NETS ON3 H1 T- ]$ h9 `. A
SPLIT_MINIMUM 04 c, R- g/ W( u* E$ c; H4 _' e
SUPPRESS 20, M2 J: @+ o, r7 l! V' K
WARNINGS ON" p6 [% d* |& E3 C( `7 @
% z+ |. I2 k1 A; @0 W
2 errors detected
4 U; M+ o. L4 N+ ^ No oversight detected
" Q, o( W+ g: |6 C8 _: _ No warning detected6 f/ w: n9 c5 c" w# f. S; P( B) U7 ?5 r
) C3 x! W' S, |; g/ O: ]5 Zcpu time 0:01:087 J* E$ }: l x1 ]& b$ f
elapsed time柙
; Y4 F3 h! i) Z/ n0 @; ] W+ b 0:00:01
/ @: F$ r9 L$ `: R0 U; |6 C M9 w4 M* {; Z K
6 A k7 Y4 T" u$ O
NETIN时报如上错误,请高人指点 |
