查看: 1007|回复: 0
求助:allegro pcb editor 出现问题
发表于 2012-7-5 16:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
求助各位大虾,我在用allegro pcb editor 布线时发现布不通了,所以就关掉软件,把原来用的文件夹删掉,然后将备份的文件夹复制过来改成更原来文件夹相同的名字,以为这样就可以重新来过,免得一个个手动去删一些线和过孔,结果打开pcb editor时,电脑提示:file "**.brd" was locked on date "july 2012~~~~" by user administrator on system "~~" would you like to override the lock ?,求大神指点啊。
GMT+8, 2025-8-4 18:45 , Processed in 0.125000 second(s), 24 queries , Gzip On.
