在生成光绘文件的时候出现了警告如下:
7 w( n5 ]3 p7 c WARNING: Photoplot window (2100000 x 1700000) exceeds film size (2400000 x 1600000)" ?- G5 H7 f, `- f& L6 g
stated in parameter file. / _; n9 t+ ^' k& G, a
: z; ^. ] |; v. I2 @( f3 n WARNING: 0 width line found at (25.000 0.000)
# k2 j C) s- j: N% ^( {5 ~ ... using undefined line width of 6.000
4 t+ q. G9 j) D* z: _. }1 H
! x: a) C# Y3 G7 ]+ O. f WARNING: Segment with same start and end points at R5 R7 T1 Q, l" { i
(3649.570 2837.730) will be ignored. Increasing output9 t$ | j; \3 K1 S6 \) V
accuracy may allow segment to be generated." H2 |4 m5 \4 ]" X, J
( h( H0 ?6 P: r: } `. d大家能否帮忙解释下,分析下,这些警告对制版有没有影响?
- m: a6 A3 u/ G. h
( B6 @/ V% O% k6 x& C谢谢。。。。。 |
