查看: 1482|回复: 5
cadence怎么出45度椭圆形孔光绘
发表于 2012-8-27 15:24 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
求助各位大神,请问cadence怎么出45度椭圆形孔光绘,45度角时,出光绘会提示如下错误。; n7 D8 E' z& S& m! A5 s3 v) _) S
ERROR: No aperture for OBLONG - 65.00 X 79.00 at (98.43 354.33) Rotation:  45.0001 q( ~; `; T0 N0 z& L- z
WARNING: 0 width text line found at (9115.00 -2785.00)- R* S9 ^7 F. U6 P: u) b' E
         ... using undefined line width of 6.00
) l( O' P9 f9 B: MMultiple 0 width text lines; all will be treated the same as the first.
' @5 }" k) a1 R, B" i( w4 h$ uWARNING: 0 width  line found at (118.11 78.74)
+ v3 X9 R$ r& w0 x# t5 f+ Q+ E         ... using undefined line width of 6.00# b5 r7 Z7 n$ ^- h; F
3 t; e1 |5 V/ j! ]/ u& Y# F! \7 j. x
+ R( |9 A* v. G# k4 k  ERROR: Artwork can't use standard geometries to flash
' N2 {& b: Y' _. c" }) h         these odd-rotated (not 0,90,270,180) pads.  This
- G0 q- e& O! y& @         design requires the use of ROTATED APERTURES.
! G2 Z* T; b+ N( s7 J (PADSTACK NAME)        (ROTATION)
, |6 g0 E2 `& B  m1 N# m! \) s9 R( G PAD79_65OB79_65U          315.000  d4 @) b2 C& H- O! f# G- t
8 @8 b7 `* m& W, h0 _
1 R5 N6 t. v/ l+ M  SUMMARY OF MISSING APERTURES:
' W) }1 Z5 H0 |% F$ x    OBLONG            65     79          45.000    (1)
- w8 z( B, _& k1 [* `0 w
! d7 ~1 ^% x7 i: u; U
* ?0 U) C8 _3 o1 S9 [& I4 J ... error in film, proceed to next!
) w+ ~/ L1 w3 x$ t$ e5 l! ^8 g/ \4 F0 T" T# y, x: l( G
    2024-5-31 15:00
  • 签到天数: 1000 天
    [LV.10]以坛为家III
    发表于 2012-8-27 18:02 | 只看该作者
    板內若有非正交(0,90,180,270)角度零件4 `- [5 c; |/ l/ W) i1 C7 L
    需勾選Draw missing pad apertures
    ( _: n/ a# z# M. o% |0 ~1 ~如圖設定" [1 V2 `/ o1 x. S- x
    45 in film.png (23.38 KB, 下载次数: 7)
     楼主| 发表于 2012-8-29 09:19 | 只看该作者
    好像还是不行哦,会不会是我们那个椭圆形孔有问题?
     楼主| 发表于 2012-8-29 11:50 | 只看该作者
    koncc 发表于 2012-8-27 18:02 + @1 U. w7 W; f) Y
    0 a' Y9 w  D- |( p6 W8 |需勾選Draw missing pad apertures: g* J% T' n9 G7 D( Y
    如圖設定
    8 \) P! }: R" r" F6 {- |还是不行哦,我用的是gerber6X00,跟这个有关系吗?
    2024-5-31 15:00
  • 签到天数: 1000 天
    [LV.10]以坛为家III
    发表于 2012-8-30 09:57 | 只看该作者
    3 n6 x. {$ T& X7 i* u. N* m
    zychappy 发表于 2012-8-29 11:50 0 s( Q) }1 g/ _: F/ f7 I. I
    $ Y% H) p' h1 n9 s! |% f7 i* C/ b
    我測試也是用6x00 轉出是沒問題的......
    ' f, B3 G: H2 [* q9 ^* L, r$ ^& l* A: P8 y+ S; ]
    請問 film 有全部勾選嗎?
     楼主| 发表于 2012-9-1 15:56 | 只看该作者
    koncc 发表于 2012-8-30 09:57 4 F! Q' n! Z, a
    ) b0 _8 p7 i9 Q  k7 e2 }0 W& _2 P
    1 G0 F2 _' W; T9 q$ y  S2 H請問 film 有全部勾選嗎?
    # m7 @2 R/ m' Z4 \; M- v- N郁闷了,
    " L* p0 T- N& {. L+ R+ k2 eNo aperture for OBLONG - 65.00 X 79.00 at (118.11 393.70) Rotation:  45.0001 d& S; B3 |$ s5 n% h7 w% D
    我勾选了draw missing pad,use aperure rotation,还是出不来,勾别的任何一项也出不来,
    ! d' ~* X+ r4 O" n+ F: Y在edit aperture station里,选with rotation或者without rotation也出不了光绘文件,我们这边的几台电脑都出不了,你出出来的光绘有在CAM中看看吗?drill会不会有问题?
    GMT+8, 2025-8-17 21:20 , Processed in 0.125000 second(s), 26 queries , Gzip On.
