从orcad里面导网表到allegro,出现以下错误:
6 M5 l# d# l. `- o8 N9 e(---------------------------------------------------------------------)
. P: Q" e; g: j* m1 f7 C3 F( )3 i# ~! y) l z# j
( Allegro Netrev Import Logic )1 i6 u l% c' F& z u% m
3 E. X% s4 M/ {9 u: n( Drawing : JC0047EKT2132.brd )
- a2 T# x* Q* v5 z$ S( N0 e4 D( Software Version : 16.5P002 )/ K4 x. G& ?/ l- u4 x3 |
( Date/Time : Wed Sep 19 10:30:51 2012 )
: ?9 W4 M" K T+ n. O( )
* \! W- ^; P) V6 x; ?# ]) b(---------------------------------------------------------------------)- ]( i7 U0 ?. d. v9 _. E
$ }1 u0 z! B1 `6 y) [
6 J! _; h; k4 p6 s------ Directives ------
+ I! c ?5 ~/ ~! ~ |
) J) S; y- Y0 x ^" Y1 |3 dRIPUP_ETCH FALSE;9 x; @* _3 M6 f) W9 c2 f' B' }
RIPUP_DELETE_FIRST_SEGMENT FALSE;: Q# f, ]! R+ p% _) \. j
RIPUP_RETAIN_BONDWIRE FALSE;
4 s( K$ X- \, K: t! a# P! q" MRIPUP_SYMBOLS ALWAYS;
* |) G0 P4 q0 ~% P5 c9 c9 o+ `Missing symbol has error FALSE;% Z @" D+ r6 j0 d9 e4 B6 X# U
SCHEMATIC_DIRECTORY 'F:\SPB16.5EKT2132\SCH\ALLEGRO';
8 O# x2 D% ~4 F0 wBOARD_DIRECTORY 'F:/spb16.5EKT2132/SCH/allegro';
$ p$ ~* P; p) ?% b3 c( tOLD_BOARD_NAME 'F:/spb16.5EKT2132/SCH/allegro/JC0047EKT2132.brd';
! i2 a9 @' @- h" W9 N: hNEW_BOARD_NAME 'F:/spb16.5EKT2132/SCH/allegro/JC0047EKT2132.brd';$ i! C0 q7 M1 K }% \2 s
& Q* S% V" Y( E* m* S( @; G8 s
CmdLine: netrev.exe -5 -y 1 -n -i
# y: Y. K( X$ @, T5 w F:\SPB16.5EKT2132\SCH\ALLEGRO
( m8 \. J5 i% x+ XF:\spb16.5EKT2132\SCH\allegro\JC0047EKT2132.brd
. _* L* Z u( C! mF:\spb16.5EKT2132\SCH\allegro\JC0047EKT2132.brd
- s2 ?) q/ T. O& U9 e4 T* f' e+ V1 G* i( l, a6 J$ i
------ ! R. @8 `7 B3 `7 }4 h, C
Preparing to read pst files ------+ E8 y6 ?' s0 k9 T3 D7 x
7 w2 f* `% v0 s- ]% j3 L5 i
Starting to read
! \" s! T2 R. T, g% ]. A( b2 m6 HF:/SPB16.5EKT2132/SCH/ALLEGRO/pstchip.dat
8 w2 T# b" I( p: j/ E5 P
% q" o! l! ?. G5 k4 eFinished reading F:/SPB16.5EKT2132/SCH/ALLEGRO/pstchip.dat (00:00:00.10)
( {# n& k& o+ u& r) @# P) s
' H. J: h/ O, ]: Y4 `( oStarting to read F:/SPB16.5EKT2132/SCH/ALLEGRO/pstxprt.dat
$ u8 @7 Y$ G# v
& L8 v9 j; ?7 m! `Finished reading F:/SPB16.5EKT2132/SCH/ALLEGRO/pstxprt.dat (00:00:00.00)# N0 p7 @8 [1 z
; \) H1 N& v. ?Starting to read F:/SPB16.5EKT2132/SCH/ALLEGRO/pstxnet.dat
/ d, @! O7 z9 r8 O8 z
# c- P4 T* U; p- ^. IFinished reading F:/SPB16.5EKT2132/SCH/ALLEGRO/pstxnet.dat (00:00:00.00)/ e6 D+ j/ S9 V* v
, g' s9 E# N7 z. l------ 4 H# P1 e& o I. x9 z4 J7 ~) b
Oversights/Warnings/Errors ------; {* [( J0 p' h' Q- C7 t8 R- P
5 l/ t; Z) Y% ^2 z) Z
O0 w: P3 \6 h9 \- M2 T' i/ e0 A$ g: G( r8 P% e. G* h+ W9 ~& i: g. E4 |
ERROR: File "JC0047EKT2132.brd" was locked on date "Wed Sep 19 10:28:39 2012" by ; W2 r8 E0 o; y$ t8 j d) \# ~0 s
user "toshiba" on system "TOSHIBA-PC".0 z5 Y% T' [8 b5 q
Resolve lock file and re-run netrev.2 n1 n& O0 Z# ~2 u- ?3 H& c( p' j
+ U* C& s3 y3 w3 H
! z( j% G7 f) p7 T#1 ERROR(SPMHNI-175): Netrev error detected.
1 o! T( J4 D+ P+ L' s0 r" @7 e; w. l- n+ j
, j/ K) w. A8 ^, T! ~) R
#2 Run stopped because errors were detected; C4 S0 i* ?, T% f _0 i# [
z8 i' N' T5 {3 y! |
netrev
5 x n- U9 C: _, x2 y$ {run on Sep 19 10:30:51 2012
$ m( [( t/ o/ R* E# _ : f& v$ G. _: d1 _# t
DESIGN NAME : 'EKT2132') @7 n% F! F: z* o6 Y' _6 C* B
PACKAGING ON Apr 21 2011 10:02:30
" {! J$ N6 g; |5 v6 ^
4 s) s1 p( v7 H' x) d . i& N) b n6 u8 q1 H: _# f$ _ s& s
COMPILE 'logic'
: y) c3 c# K+ B% F CHECK_PIN_NAMES OFF) }; n9 `5 G0 d6 N- m
CROSS_REFERENCE OFF
, {: H& I1 l7 b: C" T2 M
) n$ Z" e$ U. i0 d2 X4 D; ^ h( fFEEDBACK OFF# D+ N6 B+ Z- b- _8 v# X. M
INCREMENTAL OFF
. i7 R3 n1 P) z
) R) a5 _- {4 [% _INTERFACE_TYPE PHYSICAL
6 y+ U; U' P, H# C' G# F, Z MAX_ERRORS 500
* b- _ u9 d/ O. B9 U: v# w ' l6 h7 h/ l/ c5 R+ f* y) W
MERGE_MINIMUM 5
P, u. t, V3 S/ S/ P8 B NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
: L, l3 b+ ]* }, C7 S7 E/ A4 c
5 }8 Q( J1 U: V: v5 N# U4 c |NET_NAME_LENGTH 24$ M2 f5 A# U3 X) R: m4 B
OVERSIGHTS ON3 u6 w B8 B* H( @! Z7 H) Z' r5 ?7 r
REPLACE_CHECK OFF
, y3 Q& l. Y, T# t( g! U4 h . j" c4 F/ C) a0 B% m) Y, z
SINGLE_NODE_NETS ON# r! J: Y8 p$ Z0 w
SPLIT_MINIMUM 0
' K1 s3 x& A; W0 P) v SUPPRESS 20
7 S, v6 w. _, T' A9 K) |* ~
7 X# {! z; h/ \0 i. bWARNINGS ON
$ m& x4 y& q! w/ t/ R6 A! E. q: G9 Z" {+ T7 h0 K* ]
2 errors detected: m- E2 h# K. R" l
No oversight detected
( J3 r: [! N+ z" p# e5 h( E) s No warning detected
( I* P8 p6 H; S) k- D% c. {0 ?4 s% ?# V+ u3 Q5 X
cpu time
6 I. T" l* o( J$ M0:00:324 G. l: U: S+ E3 S, R
elapsed time 0:00:00
: K9 K8 `, i' G5 l
6 l. }; l1 u P, b3 U/ L大侠们帮看看,先谢过。 |
