还是不行噢!$ t5 t. ]% ]0 o; e4 q7 e7 h
4 i% ^$ G+ m* F% N, uLISTING: 1 element(s)" c- \; q( w% P1 D' h" `; x
< DRC ERROR > , ?& Y& W0 M& {, H: V7 z) k
Class: DRC ERROR CLASS
* i3 t2 `6 h! r. k" u+ @. { Subclass: TOP. i& f, H( C8 k0 O
Origin xy: (1550.00 1450.00)
6 V/ E& @5 s- P& \" ~ Constraint: Pad/Pad Direct Connect$ A# O$ B; |2 [' a( h5 ~
Constraint Set: DEFAULT
, j/ r" L7 I/ l Constraint Type: PHYSICAL CONSTRAINTS0 Q- S' A+ r% A$ ^- }) ]2 @
Constraint value: NOT_ALLOWED
# f a! M+ e9 \$ [, {. }3 L Actual value: VIAS_PINS_ONLY
8 ^: K: q# h `4 [ - - - - - - - - - - - - - - - - - - - -2 E4 R" S4 [/ s
Element type: SYMBOL PIN
8 T6 P1 K' N, u Class: PIN
/ a- P. ~, B$ L0 N: [2 \ PIN: U15.49
% q, P8 w- E! M6 ] pinuse: GROUND
3 D+ f" v+ N/ g6 z: c0 \ location-xy: (1578.90 1460.78) ( M- c, H+ X/ g" W$ S3 |! R* @5 z, j
part of net name: GND
8 S. r' t7 m R4 g/ k! _
2 X F) A6 r$ N9 i - - - - - - - - - - - - - - - - - - - -
) Q8 d$ ?8 [% d' M4 Z5 M9 s g Element type: VIA/ Z0 ]7 X- N4 z8 j' ^
Class: VIA CLASS
6 }$ a( f* t* W, @ origin-xy: (1550.00 1450.00) % g( a3 ?: s* V+ r4 s
part of net name: GND/ [6 `& _. u8 M, i5 ^
Connected lines: 1 ( BOTTOM )) b* `! S K$ q
Connected pins: 1. {9 l& f% C! b6 i
Connected shapes: 2 ( GND02 GND06 )
0 U+ X/ k* e3 W7 i3 K z padstack name: VIA10-GEN# C$ [- A' y+ q& J: X4 U/ P7 I
padstack defined from TOP to BOTTOM
; h/ X9 h: t: Y# P3 Y, @ rotation: 0.000 degrees7 y) t& j9 g/ h U; ?; o, z5 | x
via is not mirrored- V* J9 w7 J, e; w, G% e( ]. u
