查看: 1048|回复: 7
差分计算器
发表于 2012-12-3 13:45 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
请问16.3中的差分计算器有什么作用5 _6 q: k* c, U+ x3 |
5 C8 k  }- p& F% L7 p& V1 a: F
怎样使用呢
( u3 s% T) c% ^+ d& G' T& a
发表于 2012-12-3 14:20 | 只看该作者
参考第19页。希望有用。
约束管理器-allegro高手进阶.pdf
1.64 MB, 下载次数: 94, 下载积分: 威望 -5
参与人数 1贡献 +2 收起 理由
jin131421li + 2
发表于 2012-12-3 14:22 | 只看该作者
Using the Differential Calculator
- W! F& U" X, ?4 o& N7 h! N, f2 R! k4 t. q! i3 w- E) V
Use the Differential Calculator to perform what-if scenarios to determine what combinations of line width and primary gap values can help you obtain a particular differential impedance. The calculator is available from the Electrical CSet- and Net worksheets.
) m8 e' Z2 W' b% M- w
. ?; f! @+ J4 f! I% Y- D( X* ~0 M8 b6 s3 {' m7 Y
' l/ i  a) d8 u! ]: @You can perform calculations only for edge-coupled differential pairs on a selected ETCH/CONDUCTOR layer and account for material, thickness, electrical conductivity, dielectric constant, loss tangent, and shield.2 l& t0 c2 q% P( g
  Z" s; ~8 h. ]$ m: f- ^$ u5 f; H
$ T9 y( C" l1 G" H
3 _7 `) k( T" ^7 CLayer name
/ Y( G& k. }% h/ O, ]
& c" T& a. W5 M1 _! ^' h/ w, yIndicates the ETCH/CONDUCTOR layer for which you are running the calculation. By default, the TOP/SURFACE layer appears." R$ ]3 f" u7 M7 U1 J2 x
4 U7 u, C9 T& \7 u$ I( \8 l6 F6 sDifferential impedance
' c; K3 X- s1 w5 ^
" P% k6 s5 J+ l( m) l' jSpecifies the impedance of the differential pair. Calculated for a pair of lines having the specified Line width and Primary gap on the layer.
5 u' K3 O$ Q5 S6 a# T5 C
( t% @* x7 g* @5 I! {) DSingle-line impedance
, l5 w: e* G4 {. D: y/ ~/ `0 e/ H( {# r8 q
Indicates the impedance of one line of etch on the selected layer.
8 ~' U; D8 _2 Y$ ^* u6 N  V+ i4 P" X9 J6 {
Changing this value automatically recalculates the Line width field. Each time the Line width field in this calculator changes--either when you directly modify it or when you select it to be recalculated--this value is recalculated, too.) M$ W% F$ @' a* U6 q$ Z
2 u0 |3 }, r4 B5 q; u1 {2 b
Line width! L5 o) H/ \! c" w" f# R7 p
/ H( c. \# u) v3 ?Specifies the minimum width of each line of the differential pair. Changing this value automatically recalculates the Single-line impedance field. And changing the Single-line impedance field automatically recalculates this value.
+ u6 t0 }; e! q0 X  n2 r& I9 n- g" f! F- n
Primary gap
6 J% X4 W) F9 u+ z: }( L/ n
9 T6 t) E( }. `# x! jIndicates the ideal edge-to-edge spacing between the pair that should be maintained for the entire length of the pair.
) Z# P3 M( W4 ]2 W7 t; y. u, v
发表于 2012-12-3 14:25 | 只看该作者
你在allegro constraint manager界面。按F1按钮,然后 在右上角搜索differential calculator,查看官网的帮助说明
新建 Word 2007 Document.pdf
159.72 KB, 下载次数: 23, 下载积分: 威望 -5
发表于 2012-12-3 14:26 | 只看该作者
在哪个菜单下啊?
发表于 2012-12-3 14:44 | 只看该作者
打开约束管理器
发表于 2012-12-3 15:07 | 只看该作者
how to open differential calculator
 楼主| 发表于 2012-12-3 15:25 | 只看该作者
谢谢kangpeng
/ W, O' B- h2 W# G& X
9 F( `# F6 n& u' ?  b+ _9 H: X这个工具是否就是帮助计算合适的线宽线距以实现想要的差分阻抗?
( N2 w8 s; v, l# t  |1 Z6 I$ M$ b/ S; \
布板时大家有用到这个工具么?- x+ x* o$ u0 U# Q  _, B0 ^
: `7 r& `4 l1 p7 d4 u+ J
另资料中提到的“仅能完成边对边耦合的差分对计算”是什么意思
5 B9 k) T6 P4 r
6 T( @0 l7 e: ^* T除了边对边耦合,还有哪些耦合
9 u( Q8 }" U0 q$ k2 K- O  g3 T
GMT+8, 2025-8-21 09:24 , Processed in 0.125000 second(s), 27 queries , Gzip On.
