查看: 1233|回复: 10
PCB 导入网表出错,但是又不知道是什么错误...
发表于 2012-12-14 07:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
错误信息显示如下。。。求大神帮我解释一下。。万分感谢~~
  1. (---------------------------------------------------------------------)
    4 Y! L4 G. I, x3 P
  2. (        )
    1 N* P) B" g$ @9 l8 u# ~/ K
  3. (    Netrev allegro Import Logic                                      ); }) R+ S5 t- f5 E  @* J+ r
  4. (        )
    ) z4 u+ q3 n% Q* x& C" }
  5. (    Drawing          : SDX_Allegro.brd                               )
    + [5 N9 e2 u8 Z% ?
  6. (    Software Version : 16.3p004                                      ), }. A9 w' c, c* U5 f
  7. (    Date/Time        : Fri Dec 14 07:39:06 2012                      )' K( W7 `4 H, z( b% M. P* Y7 N
  8. (        )4 I2 H8 O! v2 B8 }$ k; K
  9. (---------------------------------------------------------------------)2 H& U1 p9 O$ A* e
  10. ; o5 o' q: c! n2 l6 d7 m! {( a
  11. . i( i7 z: Y6 c1 G
  12. ------ Directives ------
    / u" Z4 O) V. h% e; _: z
  13. 4 g1 D6 }- o* `, t
  14. RIPUP_ETCH FALSE;
    2 f, [! b7 G) ^
  15. RIPUP_SYMBOLS ALWAYS;9 n7 W  ]! y8 {* B9 D3 k% S
  16. Missing symbol has error FALSE;
    1 Y/ [, {4 T3 v. Z6 h
  17. SCHEMATIC_DIRECTORY 'D:/SPB_Data/SDX_ALLEGRO/SDX_ALLEGRO';$ \. V+ }( |6 M  ~4 h$ V! V& b
  18. BOARD_DIRECTORY '';  w& Q! [7 ?6 s6 j
  19. OLD_BOARD_NAME 'D:/SPB_Data/SDX_ALLEGRO/SDX_ALLEGRO/SDX_Allegro.brd';. X/ l' _* y0 [1 M) k. _; R4 n
  20. NEW_BOARD_NAME 'D:/SPB_Data/SDX_ALLEGRO/SDX_ALLEGRO/SDX_Allegro.brd';
    ( N8 F1 u! |; k5 P+ C6 m; ~
  21. ! J, n9 ^5 n9 A0 i
  22. CmdLine: netrev -$ -i D:/SPB_Data/SDX_ALLEGRO/SDX_ALLEGRO -y 1 D:/SPB_Data/SDX_ALLEGRO/SDX_ALLEGRO/#Taaaaaa05284.tmp. Y3 _6 |; \5 h  S6 b$ O
  23. + ?' z/ g) E' F, |
  24. ------ Preparing to read pst files ------
    1 [- `8 i3 h3 R5 @: z
  25. ( I' `% L+ C- s7 q" y0 g" F! ^5 F
  26. 7 r) X* S* s. z( V; K
  27. #1   ERROR(24) File not found
    , x; y/ b0 q  I" \: p# o
  28.      Packager files not found$ ], j' z- \8 Y4 r% \
  29. ) a. {  O' r+ D* i7 p% ]3 v! v
  30. #2   ERROR(102) Run stopped because errors were detected0 B: _) C7 i$ z' G
  31. / [  H. |- m$ {: b8 H
  32. netrev run on Dec 14 7:39:06 2012; n4 I6 l8 _* x) l# I* _/ j
  33. 0 q2 a: I& n$ d8 l% w8 t/ {
  34.    COMPILE 'logic'# B, }+ D0 H( ~- L; w
  35.    CHECK_PIN_NAMES OFF& f  N: s: L0 J; T8 [8 E
  36.    CROSS_REFERENCE OFF
    * v( @' g, c0 B% X( i' |
  37.    FEEDBACK OFF' f3 h) F% J# M# X$ O" E
  38.    INCREMENTAL OFF% \$ j1 L  E# U. [2 t
  39.    INTERFACE_TYPE PHYSICAL
    4 Z2 R" t( ?$ w' I5 _& }
  40.    MAX_ERRORS 500
    . R1 Z  F+ l# K+ O( C1 t1 d1 j
  41.    MERGE_MINIMUM 50 n2 j( ]7 T! L4 o& o$ ^
  42.    NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
    ; d; v! n; \9 v8 y
  43.    NET_NAME_LENGTH 246 e4 g+ C5 U% `6 w. t5 A
  44.    OVERSIGHTS ON7 @- B9 a7 }0 ^
  45.    REPLACE_CHECK OFF( n/ L7 t# u% l0 s
  46.    SINGLE_NODE_NETS ON
    . m' I' g. s4 D4 q6 U) w
  47.    SPLIT_MINIMUM 0
    % S+ L: J" _5 Y! d3 |
  48.    SUPPRESS   206 Y5 M8 ?( s% ^) X
  49.    WARNINGS ON6 y8 V0 f+ A8 o, X8 ?
  50. & w% l$ j7 y# P; }% m
  51.   2 errors detected0 m3 E: T6 f  p1 U5 ], N
  52. No oversight detected
    " o$ y. O( R' u' \: {0 C
  53. No warning detected4 D9 `2 a/ f" r8 F( \
  54. . |! u. E* ~8 S$ t" v
  55. cpu time      0:00:46# g4 C+ J1 P' t( C6 R' C! Q8 I4 q
  56. elapsed time  0:00:00
复制代码
发表于 2012-12-14 08:18 | 只看该作者
没有设置库路径
发表于 2012-12-14 10:18 | 只看该作者
嗯,应该是封装库的问题
发表于 2012-12-14 11:24 | 只看该作者
库的路径不对
 楼主| 发表于 2012-12-14 12:08 | 只看该作者
香雪海 发表于 2012-12-14 08:18 0 h  K! G$ m7 r* o2 B# c+ l0 i  Y
没有设置库路径
3 l- D0 R& O( k4 n1 F请问可以检测出具体是哪几个元件没有对应的封装么?库路径已经设置了啊
 楼主| 发表于 2012-12-14 12:15 | 只看该作者
jjjyufan 发表于 2012-12-14 11:24 % ?7 x7 L2 |2 G9 Z0 w- N% L- j
库的路径不对
" B6 N) W  _; \0 z+ N3 y/ d7 A请问可以检测出具体是哪几个元件没有对应的封装么?库路径已经设置了啊
651267436 发表于 2012-12-14 10:18 4 `7 m) \# a) K- Z" I
嗯,应该是封装库的问题
  q9 ?- F0 x$ s! ]+ B2 Q& q
发表于 2012-12-14 13:14 | 只看该作者
楼主的问题是,网表的路径没有指对应。读取不到网表信息啊,当然会出错。
发表于 2012-12-14 13:20 | 只看该作者
应该是,你导入的网表,不对;
8 F, o( l9 Q/ z* p  m或说你导入的网表路径不对;
6 Y$ r+ w( ^4 c( z7 |" ]4 i8 W你仔细看看,
- F& r3 I; I6 O
( i* x% k' X4 X$ m9 Z  应该是这个问题,0 U* v) h- ]7 P( X4 Y  t& K9 U; C: |( x
我之前碰到过,
 楼主| 发表于 2012-12-14 14:13 | 只看该作者
南林维京 发表于 2012-12-14 13:20
- \/ H% D6 W9 w: f. f4 Q应该是,你导入的网表,不对;- R* n) G6 H: D8 N* P8 X
或说你导入的网表路径不对;4 M% p4 Z# M0 M6 W5 j, a
你仔细看看,
. L6 f) B0 ], _7 p0 S+ n% f/ f
谢谢~~~确实是网络路径不对...
风刃 发表于 2012-12-14 13:14
7 f' M9 f6 u9 l4 m楼主的问题是,网表的路径没有指对应。读取不到网表信息啊,当然会出错。
5 |3 K0 s# K- y" c% u, s) \: }
Thankyou ...真的是网表路径不对...
GMT+8, 2025-8-21 03:19 , Processed in 0.125000 second(s), 23 queries , Gzip On.
