查看: 1974|回复: 2
【已解决】求问高手
发表于 2008-7-29 16:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本人菜鸟一个,想问一下,在做原理图时候建立了一个个人的元件库,那时需要考虑封装吗?$ |# F& `- G4 f0 T
还有本人在准备画PCB时,装入网络表时出了一堆问题,不知如何解决。# F3 Q6 v4 \2 Y
Macro 1: New Component2 f. l* a- T4 H
Add new component 1$ q9 d$ I6 ~% [  q. \6 F3 }7 c
Error: Footprint TO-126H not found in library5 Z1 c. H: f4 `$ \
Macro 2: New Component
( g; @; W) ^. u9 H! @# S  y. b: ]8 IAdd new component 2
4 S6 E- k) Y8 U& T7 }) ?Error: Footprint 12V/0.1A not found in library5 j& C+ Y! ]. f$ U* Z
Macro 3: New Component2 r: U( \0 A; `8 k
Add new component 3
( H9 {! q: k5 BError: Footprint PIN2 not found in library4 u0 ~9 l5 Y$ S6 Y
Macro 4: New Component
0 L2 w0 g3 R3 e" m- N( r1 xAdd new component 41 k# x; [* G& u1 ^" x
Error: Footprint PIN2 not found in library0 e. W  u9 q9 ?- Z3 u8 S3 X
Macro 5: New Component9 [$ Q0 s7 p: c# g8 M. j
Add new component U2
) {1 w; e7 _0 `/ L1 V. LError: Footprint CON9 not found in library! Q8 E) T0 M2 d
Macro 6: New Net
( d7 U$ R1 f) q, i* r8 e2 b" o, {Add new net NetC82 j. o8 c; ?# D! ?
Error: Net already exist2 M! i( R# N! E) k$ @5 B3 u
Macro 7: New Net
/ Z5 Q( p- d  r# p0 KAdd new net NetC9
, _3 f( i9 q# ~& U, r( G$ OError: Net already exist" P9 z4 E& ~9 s7 m$ }" S3 I
Macro 8: New Node
. U# Q: ~/ H. N1 r+ LAdd node 2-1 to net 12V2 m  F- Z8 e7 u) s8 B: e2 ^' N0 D
Error: Component not found
; D2 X8 L2 B, A1 \* ~' D0 O( dMacro 9: New Node
9 ?* n5 T8 n- B  _" W% aAdd node U2-8 to net NetR1_1* d! e& b2 K7 F' w0 F0 X
Error: Component not found- K  p0 M& |# c
Macro 10: New Node5 u  c0 N4 G% Q1 _. v
Add node U2-4 to net NetU2_4% J7 U( [" A  N: {8 a  X
Error: Component not found) `/ G/ e8 V6 Y  T# d
Macro 11: New Node
7 i) L6 r6 H) l0 gAdd node D2-2 to net NetU2_4
1 r% f/ {# V# \. I/ P2 d* w/ nError: Node not found
6 \+ h+ f% c7 O- gMacro 12: New Node
: l- J5 j4 X+ C4 k, EAdd node U2-3 to net NetU2_3* c6 e( a, u- n$ ^. e
3 C5 a% [% Q" s% B" PMacro 13: New Node
4 I$ k4 _( h% g5 f' cAdd node U2-9 to net NetU2_9
- W3 v" L  B  f& S; y7 ]. _  CError: Component not found5 }! r: C: I3 I- C
Macro 14: New Node
3 N8 n3 m* {/ W0 o, QAdd node D3-1 to net NetR3_1
5 M' O) v+ F. }Error: Node not found% m- L$ Y  ?$ e9 u& j8 @1 m. v9 i
Macro 15: New Node2 P) q& y9 V3 j, {. S
Add node D2-1 to net NetR3_1) U' U0 A; d0 Y; U) K2 U
4 m1 Y$ F# W; G* J# s3 oMacro 16: New Node
8 w0 g3 o% n6 Y: y8 [Add node 2-2 to net Net2_2, F2 `4 o8 i- ?0 I. F# g5 Y
Error: Component not found+ j% ]# X& @" P
Macro 17: New Node
3 [; w6 t  f  W. ~# GAdd node D1-1 to net Net2_28 f/ K, Y. E. ^1 F% A( C' A& F0 H
2 T! D; l% j- N3 z( [Macro 18: New Node
+ V# `6 ~  A5 q/ v3 wAdd node D1-2 to net NetD1_2
+ W5 d+ f+ n. c" r; e4 i% \4 ?Error: Node not found
1 ^& l0 }. Q. JMacro 19: New Node( M; n& q; H+ w. K: u$ w0 U, L% l
Add node C3- to net NetD1_2. l/ K$ d& t8 \! K/ a
Error: Node not found$ h. t& H6 `/ J4 t6 C) ?
Macro 20: New Node
6 [2 k9 a4 q3 g3 T' xAdd node D3-2 to net NetD3_2+ k1 L# B8 v/ C+ w; x
Error: Node not found2 B' @1 }& a4 ^/ ~$ V' `6 w
Macro 21: New Node' T: e; L, c) |) o. m& F+ ~0 }
Add node C4- to net 5V
+ N, J* ^# L' g* {1 E- V2 l+ Z$ p$ AError: Node not found0 N9 L6 A5 f" K) v, O. B
Macro 22: New Node
+ \( J+ V0 l( }4 B- UAdd node U2-2 to net 5V( P. p8 _' S5 M  a9 s# Y' F7 G
0 o: R8 b( ?8 R! D. d, m6 zMacro 23: New Node& J2 D$ e: k$ c! I
Add node 3-2 to net NetU1_147 w$ X4 O2 s6 i! Z
; \4 R1 h4 \* i, j  l. jMacro 24: New Node
4 S$ m$ R  M# m7 x. {. ~Add node 4-2 to net NetU1_156 X" J0 b- D8 h
: y2 t' @: @, u) W, PMacro 25: New Node
% m3 S) j6 ~* F" f& b) g) bAdd node 3-1 to net Net3_1
* r% `+ l3 N3 R+ E" GError: Component not found
4 f2 {4 a2 o5 Z, a6 F' r9 SMacro 26: New Node7 T& @. v1 p' v# G' C
Add node 4-1 to net Net4_1& r1 @/ v5 j% j) T+ `8 z& D, x  b- Z
% c2 \0 c' @. ]. a) TMacro 27: New Node+ S2 {, }" W% t8 X. l
Add node C8- to net NetC8
) }0 z9 Z7 B7 l+ |+ b* V( S. AError: Node not found
8 j& ^# W' B0 j3 tMacro 28: New Node4 z4 i, h/ D7 L0 s: u4 q) [
# {" I# [! ^5 N4 `7 ]$ pError: Node not found
+ I+ t( {4 r6 _5 W; kMacro 29: New Node
" B8 `9 `/ M) c4 s2 d% J# B2 Z, A# ]Add node C9- to net NetC9/ w. O6 N2 S4 a4 v6 q% f& a
2 N! Y+ ?: b& h/ o5 N3 xMacro 30: New Node6 f4 d  H0 t9 h6 ?  a0 n
  F+ g. Z/ n0 ]7 G3 dError: Node not found
3 d0 @2 C0 S, hMacro 31: New Node
7 i* \; B$ z; i8 p0 ^2 d# RAdd node U3-T1OUT to net NetU3_T1OUT' @) W8 E# n$ v: }( j$ o9 b
- e6 \3 S$ B( H0 r4 G& ~9 V: ?7 FMacro 32: New Node
8 h6 M& S9 F& n* a) R! h4 {Add node U3-R1IN to net NetU3_R1IN
4 F3 i# _. c! m, z, }; w4 d% m4 R; F: @( IError: Node not found
( p& j, v) d6 s) M2 h& r, BMacro 33: New Node$ P( F( q8 P* Z( m* m
Add node U3-GND to net NetC11_1
5 j* g; J8 U8 WError: Node not found4 a  F$ Y! F- o( P: x" d$ s
Macro 34: New Node  k3 W9 k# x  o
Add node C4- to net NetC11_1% [9 j( U7 O* R# ~8 p* T
( g& _4 X7 N1 O+ B5 jMacro 35: New Node9 b" y6 Q" q7 ]! k6 H7 o
Add node C3- to net NetC11_15 S% M! B, h& F# a, h: \
Error: Node not found. }7 l0 v$ L1 U' h
Macro 36: New Node
" O3 \" J$ ~" eAdd node U2-1 to net NetC11_1) F% e! C' e9 G# a$ c
+ f. Y% u2 s$ l2 u
: E  y3 x6 `# x( C' f- R0 c) G$ d& x[ 本帖最后由 rhymebus 于 2008-8-1 20:18 编辑 ]
cjf 该用户已被删除
发表于 2008-7-30 11:09 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2008-7-31 09:36 | 只看该作者
加入你的封装库,如果没有的话,自己就建立一个自己的封装库,以后用起来比较方便,要是不知道怎样加封装库的话,最好还是看看书。
GMT+8, 2025-10-31 16:04 , Processed in 0.171875 second(s), 25 queries , Gzip On.
