+ w/ W5 x8 d+ ]8 U5 g$ Q* ]
) z R* G: @8 F! z3 e我来详细说下我是怎么得来这些的吧
) b$ D8 S$ C# x: a; _4 @5 A我想两快PCB和在一起,利用sub-drawing 功能,(元件库已合并),发现被导入的PCB版元件序号都变成了“C*、R*、U*”,并且出现如下信息:
0 D3 t \4 B7 L! ?3 F; QClipboard Paste Session Started at Aug 14 10:11:04 2008
, Y- K5 x; C! p+ W0 [Component already placed.# f# e j5 k* I$ Q4 C
Unable to paste the symbol - ("TII_182" "PACKAGE" "J1")
, @6 |3 s1 m5 C1 ^- y6 z6 F*WARNING* (axlDBCreateSymbolSkeleton): Refdes not found - "J2"
. ~& j2 x8 r, }( \9 b, [Refdes not assigned at location X 54.19 Y 165.485
, n3 z% `2 M- b( i1 _% p) E! L8 gUnable to paste the symbol - ("TII_182" "PACKAGE" "J2") ; C' l8 R7 a e0 ^5 {7 L
*WARNING* (axlDBCreateSymbolSkeleton): Refdes not found - "M12"7 L! k* W0 F Z# }! l+ H- F6 _
Refdes not assigned at location X 54.19 Y 190.985
% h3 p/ ^) o! h$ E2 _% qUnable to paste the symbol - ("BLT_0_8_3MM_1_6MM_TOOLING" "PACKAGE" "M12") $ B- ^- L$ {- F4 r" N
*WARNING* (axlDBCreateSymbolSkeleton): Refdes not found - "M3"7 N& u' W: B7 @, h7 H7 C
Refdes not assigned at location X 49.39 Y 156.485
& f6 i8 } H0 e. e kUnable to paste the symbol - ("BLT_0_8_3MM_1_6MM_TOOLING" "PACKAGE" "M3") 1 O5 b: B" L F8 [; F
*WARNING* (axlDBCreateSymbolSkeleton): Refdes not found - "M11"
8 s/ |7 |+ H5 i' BRefdes not assigned at location X 49.3454 Y 178.0356 N2 B9 R8 Y/ m% G, F
Unable to paste the symbol - ("BLT_0_8_3MM_1_6MM_TOOLING" "PACKAGE" "M11") 8 R7 u4 U2 I3 i4 j, f! r
*WARNING* (axlDBCreateSymbolSkeleton): Refdes not found - "D8") K! }' z, J+ ~% R+ @' _
Refdes not assigned at location X 49.19 Y 199.685
3 b% A7 S; o; q& b1 N8 ~! [8 mUnable to paste the symbol - ("SMB" "PACKAGE" "D8")
( D$ N9 l7 a! L! o% X
5 Y3 v" i- T5 s2 `# {$ k最后发现网络名也变成了dummy net ,我尝试把logic enable打开,利用txt edit 功能竟然用不了
9 T: V& D4 e @0 W,在其它上面例如把R1变成R2是可以的,现在都是R*,提示can't change the refdes of anassigned component,, 然后利用assign refdes和auto rename refdes也无法更改位号
0 L6 a9 L, r1 ^" e; V, U以上请问到底该如何改? |
