大家好,我用orcad画的原理图,drc检查的时候很多警告。请问这些警告可以忽略吗?怎么样才可以消除这些警告。
% r6 Z; d) ~" q' w' ^8 \$ c3 Y+ r* W, f% a0 [6 t+ n/ d1 C
********************************************************************************. M. n! ]* U Z+ K: ?+ l
- F* ?/ X. a8 {$ `# I* Design Rules Check: @- b& j3 T2 [, w
^2 X' e5 {, b" Q' i, J3 S' j********************************************************************************
' l9 Z3 A2 k( S; Y. n& Z0 X; T
/ M# w* H& I. ~Checking Pins and Pin Connections( O8 L4 ?- L# ?
6 P5 N+ ]: l& r6 T5 X--------------------------------------------------4 l6 Q. i" }- c( e+ w
Checking Schematic: AP-RT5350-V22+ G; u) ?4 C8 p- A' \. {) o
# t0 d& A% B( }+ D! L# D8 wChecking Electrical Rules ! v& [3 A$ Z. s. h: [! c6 T2 \0 q* `9 ~+ ]
; o x0 l. z7 o) e* ]6 ~# q
Checking for Unconnected Nets
1 d, f9 T( t! y5 ^6 l- [1 x# W1 k! _% D }6 `. N! j
Checking Off-Page Connections: _% Z- a$ G2 `- c
8 _1 C* i# R" u/ R' \# |' y8 ^3 tChecking Pin to Port Connections. k$ Z, n$ A0 y' A0 n& L2 h
WARNING [DRC0013] Port has no matching pin in part instance above FactoryDefault: 6-LED, 6-LED.SCH (14.50, 1.60) . r. {0 X8 O7 D* _" J4 U
WARNING [DRC0012] Pin has no matching port in implementation below 1-CPU-RT5350,RF0IN_G0: AP-RT5350-V22, AP-RT5350-V22.SCH (5.90, 6.70) o/ w K3 v) }1 t4 R+ u
WARNING [DRC0012] Pin has no matching port in implementation below 1-CPU-RT5350,RXIP0: AP-RT5350-V22, AP-RT5350-V22.SCH (8.10, 3.30) ! d9 D9 H- @; g, ^
WARNING [DRC0012] Pin has no matching port in implementation below 1-CPU-RT5350,RXIP1: AP-RT5350-V22, AP-RT5350-V22.SCH (8.10, 2.70) 2 U1 X# h% v$ K9 D
WARNING [DRC0012] Pin has no matching port in implementation below 1-CPU-RT5350,RXIM0: AP-RT5350-V22, AP-RT5350-V22.SCH (8.10, 3.20)
- \' H, z7 q6 x) J+ s9 ^: r8 w r: @WARNING [DRC0012] Pin has no matching port in implementation below 1-CPU-RT5350,RXIM1: AP-RT5350-V22, AP-RT5350-V22.SCH (8.10, 2.60)
- i7 D% o' L& b! P# Q& E) k2 qWARNING [DRC0012] Pin has no matching port in implementation below 1-CPU-RT5350,TXOP0: AP-RT5350-V22, AP-RT5350-V22.SCH (8.10, 3.10) / w* B9 m+ f4 Y& t2 A1 ~+ g9 o5 F
WARNING [DRC0012] Pin has no matching port in implementation below 1-CPU-RT5350,TXOP1: AP-RT5350-V22, AP-RT5350-V22.SCH (8.10, 2.90) $ P$ Z5 ^5 G9 K- ?3 ?
WARNING [DRC0012] Pin has no matching port in implementation below 1-CPU-RT5350,TXOM0: AP-RT5350-V22, AP-RT5350-V22.SCH (8.10, 3.00)
& b+ t; U. v5 W# f; BWARNING [DRC0012] Pin has no matching port in implementation below 1-CPU-RT5350,TXOM1: AP-RT5350-V22, AP-RT5350-V22.SCH (8.10, 2.80)
+ x% @' H X7 P; T. ?+ [WARNING [DRC0013] Port has no matching pin in part instance above UART_RX: 1-CPU-RT5350, 13-RT5350 Peripheral-C.SCH (7.60, 3.50) 6 e {. ]$ u- g( b
WARNING [DRC0012] Pin has no matching port in implementation below 3-WLAN,RF0IN_G0: AP-RT5350-V22, AP-RT5350-V22.SCH (3.50, 6.70)
" k7 Z: s+ K! J7 b# x6 ^WARNING [DRC0012] Pin has no matching port in implementation below 4-ETHERNET,RXIM1: AP-RT5350-V22, AP-RT5350-V22.SCH (9.40, 2.60)
( }. ?! ?: I* ~3 R YWARNING [DRC0012] Pin has no matching port in implementation below 4-ETHERNET,RXIP1: AP-RT5350-V22, AP-RT5350-V22.SCH (9.40, 2.70) 1 ]* |& b% y+ l- e' v" [1 p
WARNING [DRC0012] Pin has no matching port in implementation below 4-ETHERNET,TXOM1: AP-RT5350-V22, AP-RT5350-V22.SCH (9.40, 2.80)
1 R% @5 s* ]) V: ^3 V% ]$ ZWARNING [DRC0012] Pin has no matching port in implementation below 4-ETHERNET,TXOP1: AP-RT5350-V22, AP-RT5350-V22.SCH (9.40, 2.90) 4 _3 d. _* U" r5 w' S
WARNING [DRC0012] Pin has no matching port in implementation below 4-ETHERNET,TXOM0: AP-RT5350-V22, AP-RT5350-V22.SCH (9.40, 3.00)
8 E$ u: m( {5 ?: A% z# ?9 jWARNING [DRC0012] Pin has no matching port in implementation below 4-ETHERNET,TXOP0: AP-RT5350-V22, AP-RT5350-V22.SCH (9.40, 3.10) ; Z4 {: W( F4 x' U
WARNING [DRC0012] Pin has no matching port in implementation below 4-ETHERNET,RXIM0: AP-RT5350-V22, AP-RT5350-V22.SCH (9.40, 3.20)
2 h Y7 ?$ f& I" x& j N" aWARNING [DRC0012] Pin has no matching port in implementation below 4-ETHERNET,RXIP0: AP-RT5350-V22, AP-RT5350-V22.SCH (9.40, 3.30)
@: C+ x0 P) V% x+ n0 u% W% I/ vWARNING [DRC0013] Port has no matching pin in part instance above FactoryDefault: 4-ETHERNET, 41-XMER-RJ45.SCH (18.10, 6.50) " c, V4 V+ F/ {; p" v S
WARNING [DRC0013] Port has no matching pin in part instance above UART_RX: 4-ETHERNET, 41-XMER-RJ45.SCH (15.50, 5.90)
% T# r2 R* d4 X5 ]! x+ T9 d t+ rWARNING [DRC0013] Port has no matching pin in part instance above UART_TX: 4-ETHERNET, 41-XMER-RJ45.SCH (19.10, 6.80)
: c" P+ z. p8 {; ]1 F/ }# O+ ZWARNING [DRC0013] Port has no matching pin in part instance above WLAN_LED: 4-ETHERNET, 41-XMER-RJ45.SCH (16.10, 8.90)
* }" o {( e0 b: X; z. \WARNING [DRC0013] Port has no matching pin in part instance above LINK1: 4-ETHERNET, 41-XMER-RJ45.SCH (16.10, 8.40)
* O% e* ]- r" k" ]! h$ l1 \$ ]WARNING [DRC0013] Port has no matching pin in part instance above LINK4: 4-ETHERNET, 41-XMER-RJ45.SCH (16.10, 9.40)
. |% X6 K. M1 G' RWARNING [DRC0013] Port has no matching pin in part instance above HW-RST: 4-ETHERNET, 41-XMER-RJ45.SCH (15.80, 6.10)
" t" Q3 e' ]2 J- h$ O C# m IWARNING [DRC0013] Port has no matching pin in part instance above HW-RST: 5-POWER, 5-POWER-RESET.SCH (1.80, 11.20)
, h8 i3 Q% @0 Y1 M1 L; f0 u V0 T* ^$ C) `
Checking for Invalid References
8 x5 s- `% l$ `
/ C. N5 T& Y+ x2 p" s+ O/ H- U% MChecking for Duplicate References& L0 b7 e$ t/ g# Y/ ~, j. M9 B( H# b
3 K' R2 C9 H2 B& rReporting Ports f/ }1 O2 V0 M# y; E" {
5 @" n* h5 @7 l$ p% D M
Reporting Off-Page Connections6 @/ x/ ?! n+ r$ N6 f2 h
0 f5 Y6 d* Q! ?2 `. X( a
Reporting Globals: O8 ]: F5 j* j6 K" M+ f
+ x% \: C( r6 C
Checking Visible Unconnected Power Pins( G9 n6 `" s, [9 B
+ O# m* v9 ^7 I
Checking Misleading Tap connection
- e2 j b) _$ F4 v* V0 y4 y# L0 S5 g K7 D
Check Bus width mismatch
" l- x: N% E, I) u" p6 k& e: _2 b6 K5 A/ \8 E
--------------------------------------------------4 n4 P6 |9 G+ |% h/ P, I
Checking Schematic: 5-POWER 5-POWER
8 w6 _7 z) a5 ?# [7 Q--------------------------------------------------2 b/ n. t% c) b3 Z- r
, P% O8 c, t! L' Q) D3 O& \. X1 Z9 G1 J% ?; k
Checking for Unconnected Nets4 m9 R5 H. _2 }( @7 n
7 u0 G' T z! M8 A; i4 KChecking Off-Page Connections; h: d# h2 j) y' |6 U: A
+ v9 G: C3 q; R: Z) ?9 S; x
Checking Pin to Port Connections+ P2 U& j% }% q4 B
3 c9 K* s e( C" F6 z9 u
Checking for Invalid References. g3 s( J, n7 d& B6 Q
- g$ Z1 N$ H7 r) N2 u
Checking for Duplicate References- \3 q2 T8 l Y2 ]
/ R3 e* [ m& m0 D' K7 @Reporting Ports
1 V4 V3 V+ u! B. s* j6 n6 } JTAGRST_N
; W. ~4 I* l5 D* } HW-RST
. ]3 t2 ~. n! h3 N2 ]: g8 o CPURST_N( ?) g4 z1 D1 f* k. A( r
1 S3 N4 i O9 _! w$ ~$ d O! ]
" `. p5 G% J' I, P
. d5 a6 ?; a/ ^: J, ^Reporting Globals# S$ y3 {4 O! |, s
3.3VD_J
% ^2 }4 ^/ Y" M! b3 w$ v9 q0 b 3.3VD6 A w7 ]" y' N9 m4 [5 L
VIN
- Z- j# v# \& }$ d9 h1 O; i) G3 f +5V
: h7 D. f; w/ @6 j. r GND8 r- M. H% t5 U0 I
# d* a6 K+ s% {' T) o8 c
Checking Visible Unconnected Power Pins7 U! a+ L" | ^4 W
% D. d4 h/ @+ r. O4 Q. E5 b4 `* l* {) B
. }9 @7 \' I6 a7 o/ h
4 j2 w1 e$ y J7 i: F: d) t; xCheck Bus width mismatch) u9 K9 m9 j6 M; D+ @9 |4 c9 W
% P. M$ T# G8 @
$ h: E) ^- \$ Z7 }Checking Schematic: 2-MEMORY 2-MEMORY- Y9 k9 g) {2 J4 r1 a5 }6 [
--------------------------------------------------: q* Y' X( _: I$ {9 N. E
% _+ Y& ^, W% Z0 J& _& L* X% {WARNING [DRC0004] Possible pin type conflict R119,2 Bidirectional Connected to Input Port: 2-MEMORY, 23-CONFIG.SCH (6.10, 7.40) 5 g5 J* }5 }% r8 {/ |
WARNING [DRC0004] Possible pin type conflict R113,2 Bidirectional Connected to Input Port: 2-MEMORY, 23-CONFIG.SCH (6.10, 7.00)
N* V i8 B5 xWARNING [DRC0004] Possible pin type conflict R101,2 Bidirectional Connected to Input Port: 2-MEMORY, 23-CONFIG.SCH (6.10, 6.20) 3 X( h' ] g' c( S
WARNING [DRC0004] Possible pin type conflict R107,2 Bidirectional Connected to Input Port: 2-MEMORY, 23-CONFIG.SCH (6.10, 6.60) ( {* o1 u1 L3 y$ O
WARNING [DRC0004] Possible pin type conflict R148,2 Bidirectional Connected to Input Port: 2-MEMORY, 23-CONFIG.SCH (1.90, 7.00) + m/ { b# f, j4 n# T4 S
WARNING [DRC0004] Possible pin type conflict R150,2 Bidirectional Connected to Input Port: 2-MEMORY, 23-CONFIG.SCH (1.90, 7.40)
6 W1 g' }* ~: c3 q0 BWARNING [DRC0004] Possible pin type conflict R144,2 Bidirectional Connected to Input Port: 2-MEMORY, 23-CONFIG.SCH (1.90, 6.20)
7 q. N. {6 n5 [ \9 GWARNING [DRC0004] Possible pin type conflict R146,2 Bidirectional Connected to Input Port: 2-MEMORY, 23-CONFIG.SCH (1.90, 6.60) & R, Q5 ^4 D) c+ T% Y/ r9 h
WARNING [DRC0004] Possible pin type conflict R154,2 Bidirectional Connected to Input Port: 2-MEMORY, 23-CONFIG.SCH (6.10, 4.10) 2 m) t) V" ]- C, n; B# s1 y% l
WARNING [DRC0004] Possible pin type conflict R142,2 Bidirectional Connected to Input Port: 2-MEMORY, 23-CONFIG.SCH (1.90, 5.00)
A4 T. T! p, ^3 eWARNING [DRC0004] Possible pin type conflict R136,2 Bidirectional Connected to Input Port: 2-MEMORY, 23-CONFIG.SCH (1.90, 4.60) . }9 z; M: W% W9 e) \8 ?1 k0 c
WARNING [DRC0004] Possible pin type conflict R112,2 Bidirectional Connected to Input Port: 2-MEMORY, 23-CONFIG.SCH (1.90, 5.40)
" o) B _" z/ Y" \WARNING [DRC0004] Possible pin type conflict R118,2 Bidirectional Connected to Input Port: 2-MEMORY, 23-CONFIG.SCH (1.90, 5.80) M0 q! H3 [, r
WARNING [DRC0004] Possible pin type conflict R308,2 Bidirectional Connected to Input Port: 2-MEMORY, 23-CONFIG.SCH (6.10, 4.90) $ @7 W: s1 |" l8 Q
WARNING [DRC0004] Possible pin type conflict R307,2 Bidirectional Connected to Input Port: 2-MEMORY, 23-CONFIG.SCH (6.10, 4.50) 4 |/ B* ?+ p- b. ^1 ]% B3 v/ _
WARNING [DRC0004] Possible pin type conflict R113,1 Bidirectional Connected to Power: 2-MEMORY, 23-CONFIG.SCH (5.60, 7.00)
8 w: y" `- q+ N/ m9 J1 W+ T& \; H9 XWARNING [DRC0004] Possible pin type conflict R112,1 Bidirectional Connected to Power: 2-MEMORY, 23-CONFIG.SCH (1.40, 5.40)
; ~8 h2 Z, A8 |4 ?. j. nWARNING [DRC0004] Possible pin type conflict R89,1 Bidirectional Connected to Power: 2-MEMORY, 23-CONFIG.SCH (5.60, 5.40) 7 E/ L: ] ?$ V( d9 J$ X
WARNING [DRC0004] Possible pin type conflict R144,1 Bidirectional Connected to Power: 2-MEMORY, 23-CONFIG.SCH (1.40, 6.20)
4 M2 A7 t9 A1 S. KWARNING [DRC0004] Possible pin type conflict R88,1 Bidirectional Connected to Power: 2-MEMORY, 23-CONFIG.SCH (1.40, 3.80) 4 Z, i. r) r( E+ n y5 [" A! @5 e' f7 h
WARNING [DRC0004] Possible pin type conflict R148,1 Bidirectional Connected to Power: 2-MEMORY, 23-CONFIG.SCH (1.40, 7.00) 0 }& H% M" N5 x$ L6 Q
WARNING [DRC0004] Possible pin type conflict R101,1 Bidirectional Connected to Power: 2-MEMORY, 23-CONFIG.SCH (5.60, 6.20) 6 Z+ B& K0 O) C, Z% \4 ~
WARNING [DRC0004] Possible pin type conflict R136,1 Bidirectional Connected to Power: 2-MEMORY, 23-CONFIG.SCH (1.40, 4.60) # ^$ r: _/ v2 L3 M' {2 z
WARNING [DRC0004] Possible pin type conflict R307,1 Bidirectional Connected to Power: 2-MEMORY, 23-CONFIG.SCH (5.60, 4.50)
+ X, q+ _/ M: C( O" d0 CWARNING [DRC0004] Possible pin type conflict R119,1 Bidirectional Connected to Power: 2-MEMORY, 23-CONFIG.SCH (5.60, 7.40)
2 J' j9 Q& }3 B+ D$ R5 ]WARNING [DRC0004] Possible pin type conflict R107,1 Bidirectional Connected to Power: 2-MEMORY, 23-CONFIG.SCH (5.60, 6.60) / D9 n2 [ I8 _1 E- @' D: Y
WARNING [DRC0004] Possible pin type conflict R95,1 Bidirectional Connected to Power: 2-MEMORY, 23-CONFIG.SCH (5.60, 5.80)
+ e- m9 f& N3 C( |/ @$ DWARNING [DRC0004] Possible pin type conflict R146,1 Bidirectional Connected to Power: 2-MEMORY, 23-CONFIG.SCH (1.40, 6.60) 0 _. y# v6 ^+ W! o e5 V" ~% U/ W
WARNING [DRC0004] Possible pin type conflict R150,1 Bidirectional Connected to Power: 2-MEMORY, 23-CONFIG.SCH (1.40, 7.40)
: i0 m6 M7 t& N4 |7 iWARNING [DRC0004] Possible pin type conflict R118,1 Bidirectional Connected to Power: 2-MEMORY, 23-CONFIG.SCH (1.40, 5.80) 5 C' h; h; C( R2 O. \
WARNING [DRC0004] Possible pin type conflict R154,1 Bidirectional Connected to Power: 2-MEMORY, 23-CONFIG.SCH (5.60, 4.10)
" K0 q# R% a1 Q: p. R! BWARNING [DRC0004] Possible pin type conflict R94,1 Bidirectional Connected to Power: 2-MEMORY, 23-CONFIG.SCH (1.40, 4.20) 4 H: _" ]6 \1 z4 G
WARNING [DRC0004] Possible pin type conflict R142,1 Bidirectional Connected to Power: 2-MEMORY, 23-CONFIG.SCH (1.40, 5.00) ) r3 c1 K$ m1 i* I, w' z
WARNING [DRC0004] Possible pin type conflict R308,1 Bidirectional Connected to Power: 2-MEMORY, 23-CONFIG.SCH (5.60, 4.90) . {' K- A7 [: z* D. j7 V7 k7 g3 }
WARNING [DRC0004] Possible pin type conflict R88,2 Bidirectional Connected to Input Port: 2-MEMORY, 23-CONFIG.SCH (1.90, 3.80) % s% f" w2 s: w% ~8 f" J
WARNING [DRC0004] Possible pin type conflict R94,2 Bidirectional Connected to Input Port: 2-MEMORY, 23-CONFIG.SCH (1.90, 4.20)
1 ^- K, c, D" bWARNING [DRC0004] Possible pin type conflict R89,2 Bidirectional Connected to Input Port: 2-MEMORY, 23-CONFIG.SCH (6.10, 5.40) $ J O; S# d7 E. S W/ ]3 y
WARNING [DRC0004] Possible pin type conflict R95,2 Bidirectional Connected to Input Port: 2-MEMORY, 23-CONFIG.SCH (6.10, 5.80) 8 ~; [& H2 W) {7 m* u
1 U0 ~) Q# Q6 _' }1 yChecking for Unconnected Nets
( M8 F/ G% P, }0 f3 {
) m9 E) g* l8 lChecking Off-Page Connections# p9 @- j. a) U+ M. q% T. o; p
* `; [3 m M1 J! ^' BChecking Pin to Port Connections
* G- k4 G7 k0 R' v2 W" ?2 J- _3 S3 I/ [" r/ n
. l- s0 n8 m2 m4 ~& [6 J# E
7 |# G6 w( N0 e: OChecking for Duplicate References
% t: z# N' W! d% |) M
. z: R) I; K- D( ?5 B9 M' E- cReporting Ports) o8 E5 y9 R7 B4 o. p
MDATA10
5 h. k% g8 G) V0 Q MDATA11' c: ?2 l0 Q" c
MDATA12
4 m, `" `8 C9 Q& ~3 {# O7 u MDATA13
2 q$ x4 G6 P6 s) o+ N( Z MDATA14
% C- G1 G# [' c {3 P MDATA15
5 P% y* [2 J/ ^# e4 P SDRAM_BA0- d2 e, s& e/ z2 V
SDRAM_BA12 f4 ]# D" _8 y6 R0 x5 ?+ X! {
MDATA0: @! P) o c# t2 i
MDATA1
! a# C( V, \: d; z3 G5 F" \6 j+ b1 Z MDATA2
* y4 q- z! c# g% w6 v, M. R4 a2 R MDATA36 Q+ P, k) f4 [5 K N0 [7 N1 d
MDATA4
* C% C4 g. \6 N0 r9 j2 T4 j MDATA58 m* S/ P' Q, O7 x& y" b7 f
MDATA6
8 U6 t2 M7 U( a/ C; \, s# G MDATA74 E4 p- b" q1 O$ f
MDATA8
) q+ r+ k0 R0 a: H& Q4 Y: H" T* n MDATA9
1 F- o3 e! Y6 H* q SDRAM_MDQM[0:1]
; ?' A$ C% z- Z5 \# }) c9 X9 K MDATA[0:15]
% _% ?8 t6 j& T6 c7 o4 b8 W SPI_MISO" u2 \ t) [5 ?5 w/ d1 D- ]
MADDR[0:12]5 E* ~# M; @2 [$ W- n4 v
SDRAM_WEN4 Y; H4 h( Z: ~; }% k3 m
UART_TX
4 U+ Y* k- w6 N TXD
) M6 G3 Q9 p; X; {& w8 B WLAN_LED
4 W7 n. z, n8 I. | SDRAM_MDQM0
9 w$ t, P/ R3 x; G1 U' R8 k/ d SDRAM_MDQM1
, H; g, O2 T1 S5 d4 c# r; z8 ? MADDR10
2 l& f E& `& S. D& \% q MADDR11" i7 ?) ~7 p6 u3 M5 |
MADDR12
; @0 k( u! F; u4 ?. l SDRAM_CLK_P
4 y" z1 Z4 ^* q LINK00 O t% p4 G/ u _1 X7 K/ _
LINK17 V' N' K; K7 f- ~( s
LINK2; R& o! A+ Z* u* y" Y; y
LINK3
8 w6 D: u+ f3 n LINK4
- C: k# H5 ^ F; S. O SPI_CLK
, W* F! F' [+ U& K% E% [ SDRAM_CS0N! c% @. F3 Q- r! b9 ~$ b0 W+ j/ X
SPI_CS08 D# t+ ~! x6 L: d5 p
MADDR0
7 u E; x( D0 T% t0 ^1 I4 o% {5 u MADDR1
% f: W0 s; f+ f B MADDR2
8 c O8 i' `2 ` MADDR3
4 G6 G6 [/ Z/ `9 e- V9 T MADDR4, X: J* R' K% Q" w; r
MADDR54 g% X+ a. k; [" k7 N
MADDR6! \6 V3 n( z6 T
MADDR7
; O. F* B" C0 a1 u- o4 s+ [" } SDRAM_RASN
- d8 o+ W$ u! M$ ? MADDR8% p* g: Z3 ^7 ]) {7 A9 J. i
MADDR9# F6 Z( ~, H$ A
SDRAM_CASN3 ~8 N0 ] T5 S2 ~; U& e+ R1 m
SPI_MOSI
2 I# V8 i G9 q( ? SDRAM_MCKE4 k% [* X; K- ?" O7 w8 {2 V! t3 y
1 c4 I1 s+ @) _3 |Reporting Off-Page Connections
9 z5 w; Q, N/ H* L: J6 [, V5 e# c; A' w" X# f) @# X3 Y# k, R
Reporting Globals( `% O0 Y8 [. z- }$ S) e, D7 G
3.3VD_J n2 C3 ?; A% l% p V6 Y
3.3VD
( h" Z" o9 A) t* C0 e8 Y GND4 c2 F. c, ~: p
3.3VD_SD4 e# x5 k' t% ^* l
& Q5 t$ h' M% G) Y: s9 y4 cChecking Visible Unconnected Power Pins6 a5 N, E# q2 S6 F1 |
' T9 A. m+ ?0 l9 D* GChecking Misleading Tap connection8 }4 S4 [! B; F, V" W( m
. n W4 O u7 p% b6 i! B9 h' QCheck Bus width mismatch
( c- a! q7 e/ Q! h3 Q: x4 X6 U' Y) D7 I9 j6 p) e$ m/ z
7 ~2 }' Q% @" E7 F+ [& N1 C2 |Checking Schematic: 4-ETHERNET 4-ETHERNET, U. C' x. I, W" t2 `2 {
+ s' v8 t- F) C% Q) h# o8 b9 dChecking Electrical Rules
- V4 b8 ]& C' Y6 Y L0 d7 MWARNING [DRC0004] Possible pin type conflict U20,TD- Bidirectional Connected to Output Port: 4-ETHERNET, 41-XMER-RJ45.SCH (8.60, 11.40)
! `/ J* v2 b, f0 ?6 z, w; ]' O" UWARNING [DRC0004] Possible pin type conflict U20,TD+ Bidirectional Connected to Output Port: 4-ETHERNET, 41-XMER-RJ45.SCH (8.60, 11.20)
% F2 w- J& T* J k1 m& xWARNING [DRC0004] Possible pin type conflict U20,RD- Bidirectional Connected to Input Port: 4-ETHERNET, 41-XMER-RJ45.SCH (8.60, 11.00)
, ^0 T) p$ q6 ?9 J3 N+ xWARNING [DRC0004] Possible pin type conflict U16,RTD-1 Bidirectional Connected to Input Port: 4-ETHERNET, 41-XMER-RJ45.SCH (8.50, 2.60) 4 w1 m4 ^8 s* p5 I/ u2 h% g- |
WARNING [DRC0004] Possible pin type conflict U16,RTD+1 Bidirectional Connected to Input Port: 4-ETHERNET, 41-XMER-RJ45.SCH (8.50, 2.40) ! C H4 P6 b; c8 b9 D" A7 s
WARNING [DRC0004] Possible pin type conflict U16,TRD-1 Bidirectional Connected to Output Port: 4-ETHERNET, 41-XMER-RJ45.SCH (8.50, 2.00)
( D6 J+ ]3 b6 X) ~$ IWARNING [DRC0004] Possible pin type conflict U16,TRD+1 Bidirectional Connected to Output Port: 4-ETHERNET, 41-XMER-RJ45.SCH (8.50, 1.80)
: U& b5 ~" r( X( X' kWARNING [DRC0004] Possible pin type conflict U16,RTD-2 Bidirectional Connected to Output Port: 4-ETHERNET, 41-XMER-RJ45.SCH (8.50, 3.60) + f4 d2 o0 }# s% l' B
WARNING [DRC0004] Possible pin type conflict U16,RTD+2 Bidirectional Connected to Output Port: 4-ETHERNET, 41-XMER-RJ45.SCH (8.50, 3.40)
: N }# B9 \1 b2 E5 }2 q7 ]4 V& rWARNING [DRC0004] Possible pin type conflict U16,TRD+2 Bidirectional Connected to Input Port: 4-ETHERNET, 41-XMER-RJ45.SCH (8.50, 3.00)
& I3 T& |8 t4 K; j4 P4 OWARNING [DRC0004] Possible pin type conflict U16,TRD+2 Bidirectional Connected to Input Port: 4-ETHERNET, 41-XMER-RJ45.SCH (8.50, 2.80) / d! ^, \7 c, Q: @1 Q% M4 T
WARNING [DRC0004] Possible pin type conflict U20,RD+ Bidirectional Connected to Input Port: 4-ETHERNET, 41-XMER-RJ45.SCH (8.60, 10.80) ; y$ p5 s' p# w' C6 D/ t/ y
0 D, [" `. @3 P# g
Checking for Unconnected Nets6 y7 R2 c$ X' |% k* P# c. }
8 B4 r8 x2 y) d
Checking Off-Page Connections1 W# f3 l' O4 r9 ]% m
- H2 v" r, o; R0 \% hChecking Pin to Port Connections c3 D4 A' g$ K4 W& R, R
: x" h- y4 s i% Z J
9 u4 d2 H) s7 A* `; |( P
' ]8 C; W) u# _Checking for Duplicate References
$ H, B0 F' G+ k6 y& `6 T! t$ e# T% P8 O9 r
Reporting Ports
* R! R: @% o" @: L! Q4 H FactoryDefault9 \. J, L5 z1 W5 `
UART_RX, G" v; v# h+ Q+ x) }) X1 k# `
UART_TX
; |7 C& [9 r. ~. d4 `- F, C WLAN_LED
1 b R% G& ?! Z5 ^ LINK1
* ~& D% y% d8 M7 | LINK4
+ j- B" N5 r3 A, t4 ]' K% I TXOM2
# \' j1 }5 K& z9 b TXOM39 @) u! E% V4 N5 c! k
TXOM4
- g5 R7 D s0 r- _2 F TXOP2
7 ? U' r/ ~( o! r% Z; j% H TXOP3% Q; A) x' o) b: ` i- ~
TXOP4/ }) _" @. ?7 e6 ?7 X. a+ [- s
HW-RST5 s5 L+ \+ x* }8 ?) K3 \, v3 E% |6 A
RXIM2
+ s, s1 L3 `4 @! F: h RXIM3 O4 t1 ?) ^2 n! M) `1 \
RXIM4
! t K( y m6 S, R2 N/ P RXIP2$ G3 J& B4 B, _' R: `) L, P& e0 y
RXIP3( f; j5 b8 N, o. E! ^- m! g
RXIP4/ N9 V& r( ^. E; H' `3 J8 g
7 w! e8 u/ t9 p7 i+ q+ `Reporting Off-Page Connections6 {6 q$ r! r( z
5 A6 f& T4 p. L. h3 ]/ e) s* m
Reporting Globals9 p$ |$ X l0 D6 I
CHGND
) z7 E/ Y6 R; ? +5V4 m$ X! m% p8 W9 A, ?0 C
GND6 w+ ^( d h0 Z4 c
SOC_1.8VD# {6 K/ z+ y& ^2 X
8 H& t% V/ s& J% h* @( V; _& p
2 l+ }% b5 m& E6 d/ H0 f
) n- N; C5 T% W' B! g9 AChecking Misleading Tap connection, b6 d8 F- n! P9 i p
0 l; Y5 R5 F" t6 V* T! J r6 c- fCheck Bus width mismatch
% s2 o4 g" T \0 [
0 @- ]' ~; I8 a% S- \( A--------------------------------------------------
; J% L% W, N# S7 c2 [7 H; f# E! BChecking Schematic: 1-CPU-RT5350 1-CPU-RT53502 ?* X+ N7 _3 e3 a2 A: i. V
2 v. F) s; D* XChecking Electrical Rules # O2 K9 G2 Q* {! s) D, G
WARNING [DRC0004] Possible pin type conflict J4,3 Bidirectional Connected to Output: 1-CPU-RT5350, 13-RT5350 Peripheral-C.SCH (8.70, 2.60)
% U6 s3 R; c1 d( T) O3 W9 wWARNING [DRC0004] Possible pin type conflict J4,3 Bidirectional Connected to Output Port: 1-CPU-RT5350, 13-RT5350 Peripheral-C.SCH (8.70, 2.60) $ n0 K, [5 v! M- i# U Q- q
WARNING [DRC0004] Possible pin type conflict U1C,I2C_SD Output Connected to Bidirectional: 1-CPU-RT5350, 13-RT5350 Peripheral-C.SCH (4.00, 2.60) 6 f0 z3 Z- t- k4 f+ N# g
WARNING [DRC0004] Possible pin type conflict J4,2 Bidirectional Connected to Output Port: 1-CPU-RT5350, 13-RT5350 Peripheral-C.SCH (8.70, 2.50)
# b: G' ^1 T. u! p7 BWARNING [DRC0004] Possible pin type conflict U1C,GPIO0 Bidirectional Connected to Input Port: 1-CPU-RT5350, 13-RT5350 Peripheral-C.SCH (4.00, 3.40) 6 w+ E n' W E( e
WARNING [DRC0004] Possible pin type conflict U1C,DSR_N Bidirectional Connected to Output Port: 1-CPU-RT5350, 13-RT5350 Peripheral-C.SCH (6.40, 1.50) ' I8 Q$ _$ q5 q$ x) x/ D9 x
WARNING [DRC0004] Possible pin type conflict U1C,RXD Bidirectional Connected to Input Port: 1-CPU-RT5350, 13-RT5350 Peripheral-C.SCH (6.40, 1.80)
. z3 a5 _8 S, ]6 qWARNING [DRC0004] Possible pin type conflict U1C,RIN Bidirectional Connected to Output Port: 1-CPU-RT5350, 13-RT5350 Peripheral-C.SCH (6.40, 1.70)
1 I8 d" B+ |5 o8 k( J" k) e% [: Y& s2 yWARNING [DRC0004] Possible pin type conflict U1C,CTS_N Bidirectional Connected to Output Port: 1-CPU-RT5350, 13-RT5350 Peripheral-C.SCH (6.40, 1.60) 5 ~7 l" f' u% q( n0 ?5 M L3 v
WARNING [DRC0004] Possible pin type conflict U1B,MA9 Bidirectional Connected to Output Port: 1-CPU-RT5350, 12-RT5350 SDRAM I/F-B.SCH (8.50, 1.60) " {9 g o4 }0 w! b
WARNING [DRC0004] Possible pin type conflict U1B,MA10 Bidirectional Connected to Output Port: 1-CPU-RT5350, 12-RT5350 SDRAM I/F-B.SCH (8.50, 1.70)
+ v# |% y$ M( a& Y: Z* a7 t3 `2 }WARNING [DRC0004] Possible pin type conflict U1B,MA2 Bidirectional Connected to Output Port: 1-CPU-RT5350, 12-RT5350 SDRAM I/F-B.SCH (8.50, 0.90) 5 ?( D1 B# r, f' Z
WARNING [DRC0004] Possible pin type conflict U1B,MA0 Bidirectional Connected to Output Port: 1-CPU-RT5350, 12-RT5350 SDRAM I/F-B.SCH (8.50, 0.70)
, a' o6 `7 `1 a4 s9 LWARNING [DRC0004] Possible pin type conflict U1B,MA6 Bidirectional Connected to Output Port: 1-CPU-RT5350, 12-RT5350 SDRAM I/F-B.SCH (8.50, 1.30)
|' h4 I7 ]; Q( oWARNING [DRC0004] Possible pin type conflict U1B,MA1 Bidirectional Connected to Output Port: 1-CPU-RT5350, 12-RT5350 SDRAM I/F-B.SCH (8.50, 0.80) : }% g" [' C$ u3 F% X, ^$ ^7 r
WARNING [DRC0004] Possible pin type conflict U1B,MA5 Bidirectional Connected to Output Port: 1-CPU-RT5350, 12-RT5350 SDRAM I/F-B.SCH (8.50, 1.20)
5 a4 A, C4 ? y1 RWARNING [DRC0004] Possible pin type conflict U1B,MA3 Bidirectional Connected to Output Port: 1-CPU-RT5350, 12-RT5350 SDRAM I/F-B.SCH (8.50, 1.00) $ A( ~) F- y* d! @8 U
WARNING [DRC0004] Possible pin type conflict U1B,MA7 Bidirectional Connected to Output Port: 1-CPU-RT5350, 12-RT5350 SDRAM I/F-B.SCH (8.50, 1.40)
3 r$ z/ R( M% g6 aWARNING [DRC0004] Possible pin type conflict U1B,MA8 Bidirectional Connected to Output Port: 1-CPU-RT5350, 12-RT5350 SDRAM I/F-B.SCH (8.50, 1.50)
0 i4 O& d. H. jWARNING [DRC0004] Possible pin type conflict U1B,MA11 Bidirectional Connected to Output Port: 1-CPU-RT5350, 12-RT5350 SDRAM I/F-B.SCH (8.50, 1.80) & D/ M" M+ u* E# X, |
WARNING [DRC0004] Possible pin type conflict U1B,MA4 Bidirectional Connected to Output Port: 1-CPU-RT5350, 12-RT5350 SDRAM I/F-B.SCH (8.50, 1.10) * N0 e' b' V5 u5 c/ Z w5 }
WARNING [DRC0004] Possible pin type conflict U1B,MA12 Bidirectional Connected to Output Port: 1-CPU-RT5350, 12-RT5350 SDRAM I/F-B.SCH (8.50, 1.90)
; S$ |: Y7 \% J" f. b$ iWARNING [DRC0004] Possible pin type conflict J4,1 Bidirectional Connected to Power: 1-CPU-RT5350, 13-RT5350 Peripheral-C.SCH (8.70, 2.40)
) x9 p' Z r7 u4 n$ [) Z! NWARNING [DRC0004] Possible pin type conflict J4,4 Bidirectional Connected to Power: 1-CPU-RT5350, 13-RT5350 Peripheral-C.SCH (8.70, 2.70)
4 e( L8 z1 _: M( C- z: F
; H# [' ]+ n) V( P9 XChecking for Unconnected Nets
: m4 X F, Y: @9 Y! u; f4 F% J' a
Checking Off-Page Connections- W+ j4 @& U: _ I/ Y
9 C) |2 f" ]! _
/ f2 X% x/ b0 N) m9 y2 x
3 y- { j5 N3 k3 nChecking for Invalid References" u5 z2 w8 k" E' A. Y3 ?
, s! w- O4 j8 r. yChecking for Duplicate References6 a2 M6 P" I3 ~9 j
! C) `0 r" h" ~& ?5 E1 a: g; a& V
Reporting Ports
5 C Q0 Q5 Z- N! i( [5 c3 j MDATA10" o3 v$ f" N4 g7 @
MDATA11' R- ]+ y7 t8 U' x
MDATA12
# c' `* j( Y; b, h2 X MDATA13
. r# ^# {, s8 `6 Y+ N5 [) f9 Y MDATA14. J' G3 {$ F9 D6 q/ h
MDATA15
; b" J- C" x: \ SDRAM_BA06 a; l6 p7 Z1 [* ~3 M1 I* L+ l7 r; b6 X
SDRAM_BA1
1 q, [2 l* ~: a: p {( G4 X MDATA0
$ F5 ?3 k. c, Z# R) I- E# @ MDATA1' w7 l+ |; N) s# U2 n
MDATA2
% ]6 L+ C9 C% H( b8 h" i" m MDATA3
1 Y8 H( w/ V7 Q8 Y3 I% [ MDATA48 z7 R. i9 ?9 R+ H6 R# R
MDATA5
: R P V; g; Q9 O* { MDATA68 c* n; [( g2 l6 ~; y! u3 A0 l7 p
MDATA7
, b# V' f. \4 z6 ]; w' k7 M MDATA8
* [ q3 |# \1 E+ n c MDATA9; u" e" D0 P0 I- x$ a
MDATA[0:15]+ k8 ~' W b" v5 n+ W$ D+ d
SPI_MISO
% I+ G. [7 A, \0 H/ L WPS_LED
; V7 ], V$ l) P+ c MADDR[0:12]
/ `) y1 A2 W; d9 k SECU_LED
9 G( `; p; I" e" f9 }/ s SDRAM_WEN4 v2 @7 v1 X0 a: f) j
UART_RX
& t3 Q. h, d" |& d UART_TX) x$ |& U1 y+ P# d; i/ L& D
TXD
3 R6 `4 H% w4 S JTAGRST_N/ l6 E9 u' I( [8 S* I
WLAN_LED
5 D% u' n) H. [2 N SDRAM_MDQM0* @, o. v* ^" m# J2 {/ y
SDRAM_MDQM1$ @+ {- s. q6 _* q: z# `2 j
MADDR106 a2 ]# I% O: C- ~
MADDR11* ]0 l- c, Z/ h/ l+ u
MADDR12$ j/ [- ?$ {, u
RFOUT_G06 p9 U; D7 |# M* j2 ^- i l- P
SDRAM_CLK_P! w3 P" a. |: a, [. ?
LINK0
" C6 {# |7 k( F2 T LINK1- K. c9 I& L: w5 T5 Y$ ~
LINK2
9 j! W% b1 K7 k LINK34 V. {6 Y1 |5 T$ T! X) a: t
LINK4
' C" v u( O0 Y9 @* [$ e RST_PBC/ T8 P1 S2 _8 ?4 T( b$ @* I
TXOM2
) r- b/ q/ A/ F1 G& ?$ o4 F% `8 @& H TXOM31 |. J% @3 j) @- r4 F v4 ]
TXOM46 ~" f2 B) A; n t+ b, U
TXOP2
9 c+ S, ~, L m0 [3 {1 {% J2 @ TXOP3
) P& `5 a3 w: O TXOP4
" L' y, S( ]) X# H$ ~ SPI_CLK# m: g0 H' C, m$ q
SDRAM_CS0N i4 S, {) T/ Q/ [8 \5 t
WPS_PBC
+ b6 o/ H6 i; n t SPI_CS0! n+ V& w3 D4 R. Y f; }2 E0 ^
MADDR0& _, r* ^, ] D) a* v/ w) n
MADDR1% O( D! A3 F5 k5 ^
MADDR20 w+ [' J, ]7 J& Q' ]
MADDR3# q! G0 N7 p& l) s
MADDR4" U3 u# U1 s2 S7 U' w' B
MADDR5- p, i2 V3 D# a' A, }' z
MADDR6& a6 {# L' r0 _
MADDR7, u! }& X9 q8 C9 e7 ^: v0 I% N
SDRAM_RASN
# g1 V4 p/ a( d8 W6 t; A6 s1 A0 ^ MADDR81 p5 ]7 k _' z% g# p4 }4 v
MADDR9- _$ g& q- V% }; d
PWR_LED
! h9 t% r d! y SDRAM_CASN a3 K, p; M& J3 N
SPI_MOSI
5 d+ X2 F+ B) t8 r9 ~* o- C SDRAM_MCKE. k/ Q4 m5 P l2 G, R" d
CPURST_N
, z. y: J/ ^; N- {) T* o% ? RXIM2( z/ f' Y7 r& V; B% i* B$ n" v5 \
RXIM36 V+ Z) t* a9 C6 v
RXIM43 w4 M8 `" Q4 y9 ?% ^9 H7 J
RXIP2' b; T' N& o1 W* Y+ W; e; ?# v
RXIP3* O2 k- T4 G: V! `
RXIP4; l8 P( r x5 X) q
/ f- a! B1 ~3 W$ o2 UReporting Off-Page Connections
( U0 F$ u7 @3 j4 ^8 `# X
9 u4 G3 j! K' G; CReporting Globals
0 ?% b% `( t% C/ I; P 3.3VD_J" ~$ F+ ^9 z+ e) G. l& B
3.3VD% x( D( Q# O' l
DCDC_V33A
& o9 V% ^) b9 I% W! T8 y3 Q4 d# N DCDC_V33D9 Z# `$ M, b0 M! P
SOC_1.2VD4 n0 @6 W7 k$ J& [3 i* b+ Z% }* z( n
GND
0 Y* o% i% H0 } SOC_1.8VD
K: j& r. O! W4 _: N- [$ j( v$ L
% H! F" m& v9 @+ r% y, }, r- {% j$ x
) q3 w0 N' m- r) A, nChecking Misleading Tap connection
9 j' Y( d% t" ^" j1 b9 N' M( o0 Y4 ]+ j4 L" Y
Check Bus width mismatch9 H; E8 m/ F+ i* [0 W
6 H- R+ F! }5 x6 P0 g* P$ p
. f5 k- R5 S" W1 B5 VChecking Schematic: 3-WLAN 3-WLAN3 R7 b$ ~5 ^0 @1 L/ ?, x
--------------------------------------------------0 f' a# n" L' z+ r! a# m
Checking Electrical Rules 4 t1 L' y- O' O9 E; _0 @
. \' b, u0 b$ }0 Q& I3 a( I
& d# c7 v+ ~0 @5 o: B
5 H" u8 x6 k% o3 }Checking Off-Page Connections6 N9 U* H" p2 C1 N! `6 b/ b
1 q( `/ G6 l/ }* N1 UChecking Pin to Port Connections5 W* E$ M7 }! W$ \, t3 }
/ i% F$ Y3 r5 R6 ^4 l1 N
Checking for Invalid References5 e& K( {( ~- z( [2 G
; u& ]- {- m5 M) v4 V, C
Checking for Duplicate References/ Y6 I/ I X. v8 I6 x7 Y) c
2 M" S2 O- x( j7 o2 w/ oReporting Ports
- s2 Y6 y9 b; x! s+ b RFOUT_G0+ z) s d4 j5 J) i" }0 ]8 W$ T' Y" }
/ R( {, ?6 l% Z$ s8 j6 o) SReporting Off-Page Connections% L7 c& r% T z5 r
# f. {! w8 z: o; h. E: O" p
Reporting Globals
& Q* s3 ?6 q1 O% m GND9 [8 t- q3 z+ s
' N8 Y- c/ h6 U* Q, M0 [$ f% QChecking Visible Unconnected Power Pins# G$ h/ h3 |$ X! o
) Y( _$ A, Q% C" OChecking Misleading Tap connection
( [% p5 I- v* [# J' y1 m, K r' P2 G% V8 X# ~) T
7 P4 @; s5 n0 b) @& f* {9 ~' T0 w3 h0 ]6 D1 K) e: n
--------------------------------------------------- P2 G: E1 u3 r7 b- c1 X
Checking Schematic: 6-LED 6-LED) i, P4 X% ?) s7 w# E8 G# J& C
--------------------------------------------------" K3 m# E; g' a4 v$ F$ l) @
4 f3 B/ p. l, _9 ^# P% u3 Y1 _. c9 s3 `& b S+ n! ~. h/ _! S. L4 i
Checking for Unconnected Nets, K. w% U' a" E, h! P: @# s
' E8 D) Y; V+ h0 N+ k6 p4 p
% V: a1 P8 E3 V6 t9 J
: | p6 E6 `- p+ T {" ZChecking Pin to Port Connections
/ |9 K$ H3 x1 n1 B' O- j
; w9 G) D9 u& y. e) ], XChecking for Invalid References6 ]$ W0 \' n8 [
4 Y/ k) O4 J, d2 t$ O
Checking for Duplicate References' m2 U# A+ r; n' c/ S, Q8 u* V9 C
6 p0 v- u/ |8 t" O9 T0 SReporting Ports
7 u/ `1 e& l8 ]+ v0 n FactoryDefault/ ~3 O0 b% L% ^# P
WPS_LED9 L0 _# h8 G/ @, J- d
SECU_LED
+ ^3 ` H! D7 M- m' J9 ]8 m6 z WLAN_LED
" z7 X3 S" j1 R; a0 H9 a# j; T LINK01 G7 N% k8 c. G7 F6 B- {$ E
LINK1
- {7 A/ J% h; S, B. ] LINK2/ y: L5 i c3 @8 X1 f: t
LINK34 P# q1 L) Z* l& h9 g4 t0 J, B6 a
LINK46 O) u* L# r& I
RST_PBC9 {0 D3 j1 a6 @7 I3 b
WPS_PBC+ N( p# e7 f# h: d) D1 f0 D
PWR_LED
2 c, x. J& \' Y1 l; h" A( N# Q2 b5 Q: ^; n- m1 P2 |0 s
Reporting Off-Page Connections1 P" E. Z3 W+ i1 U! ], s7 _
5 J" U& b/ X( Y% lReporting Globals y- E8 Y6 p& P% G- ~5 z
3.3VD_J4 ^, s3 l1 K4 |
3.3VD
M8 |9 A! z- Y( g GND
7 e9 x ?: X: d3 G! V8 M9 [; m3 E; T' E: }2 F8 y
; R+ ^ Q% G9 \" C1 r, [5 ~1 J; s1 G0 S* @" x5 O
9 [! p7 a+ x! y/ P0 w. A6 S
' o0 @. V; j2 X; l+ O& ICheck Bus width mismatch
3 n0 h9 |) L7 \$ X) X4 n |
