洋人的建議
: e* L8 z; @3 a' F4 C# A' V! t' P$ e1 @7 M% a
如果是在仿真時發現問題
4 r8 c3 `% n* y! b; B$ qIf this is in a simulation:
) ]) f; \, X9 w% B }' x3 I- Make sure you are looking at the receiver signal.
- Make sure your IBIS model waveforms for the driver look good.
- Make sure you are using an LVCMOS or similar input impedance receiver." A* ?" q. M2 @ Z8 z1 C
+ e2 _4 u6 f0 c6 `1 F) {; x( X如果是在量測時發現問題
; [3 h! f5 Y" H+ S) D |/ q* rOr if this is a lab measurement:
+ v' P$ c! D2 Z4 R6 w$ f- Make sure you are looking at the receiver signal.
- When measuring, make sure you are using a high bandwidth, high-impedance probe, that is connected close to the receiver without any large wires on the signal probe or the reference connection.
- If you are doing all that, this glitch could also be crosstalk or ground bounce, so you may want to look into that as well.9 r# m% S* R0 _9 J& A
4 p4 s( J A8 X. ~' o
" E$ j! k9 V" @! ? |
