#include <reg51.h>
sbit key0=P1^0;
sbit key1=P1^1; //定义key0,key1接口
unsigned char flag,con,mcount; //flag为计数到一秒时给时钟发的信号
unsigned char count = 0;
unsigned char seccount =0; //作为时钟的秒的计量单位
unsigned char hour = 0; //时钟的时
unsigned char min = 0; //时钟的分
unsigned char sec = 0; //时钟的秒
unsigned char keypress0,keypress1,mode,ms,s,ss,start;
unsigned char
Displaynum[]={0x14,0xd7,0x4c,0x45,0x87,0x25,0x24,0x57,0x04,0x05, 0x10,0xd3,0x48,0x41,0x83,0x21,0x20,0x53,0x00,0x01,0xff,0xfb};
//数码管十六进制译码表
unsigned char controlnum[]={0x08,0x04,0x02,0x01}; //控制四个数码管显示
unsigned char DisplayBuff[]={0x00, 0x00, 0x00, 0x00}; //每个数码管的值
void display_state(); //数码管显示子程序
void keyscan(); //键盘扫描子程序
void timer(); //秒表子程序
unsigned char count1,flag1,t_adjust=0,tm_adjust=0;
unsigned char bKey0Pressed = 0, bKey1Pressed = 0;
unsigned char ucStatus = 0;
void main()
TMOD = 0x01; //定时器0工作在模式1,GATE=0,C/t=0,16位模
TH0= (2^16-5000)/256;//定时器0 预存值,
TL0= (2^16-5000)%256;
TR0= 1; //定时器0 启动
ET0= 1; //定时器中断0 允许
EA= 1; //开中断
IT0=1; //外部中断0下降沿触发
IT1=1; //外部中断1 下降沿触发
EX0=1; //外部中断0允许
EX1=1; //外部中断1允许
PX1=1; //外部中断1 为高优先级中断
: C# q8 U* X! E( @+ D Z
while(1) //死循环,
if(flag == 1) //时钟显示
flag = 0;
sec++;
if(sec ==60)
{sec = 0;
min++;
if(min ==60)
{min = 0;
hour ++;
if(hour == 24)
hour = 0;
display_state();
keyscan();
timer();
" z9 T3 r P& F% I5 n }
//////////////////////////////////ISR中断服务程序,每5ms产生一个定时器0 中断
void Display() interrupt 1
TH0 = (2^16-5000)/256;
TL0 = (2^16-5000)%256;
" [ @0 z6 u3 k
seccount ++;
mcount ++;
keypress0++;
keypress1++;
& t' g H9 O( N& [ u/ m; ]# u* l l P2=0x00; //P2口先清零
P0 = Displaynum[DisplayBuff[count]]; //P0口输出
P2 = controlnum[count]; //P2口输出
3 h- _7 M3 p! c$ z, e5 f9 }8 x
count++;
if(count==4)
count=0;
if(seccount == 200) //200*5ms=1s
{ seccount =0;
flag =1; //每过1秒给时钟信号加一秒
. C: ^- i& e) z7 Q5 f }
8 K/ [: |% k9 u8 f///////////////////////////////////////////
if(mode == 0) //时钟模式,显示时间
DisplayBuff[0] = hour/10;
DisplayBuff[1] = (hour%10)+10; //"+10"是为了显示加点的数字
DisplayBuff[2] = min/10;
DisplayBuff[3] = min%10;
if(mode == 1) //秒表模式,显示秒表
DisplayBuff[0] = ss +10; //"+10"是为了显示加点的数字
DisplayBuff[1] = s/10;
DisplayBuff[2] = (s%10)+10;
DisplayBuff[3] = ms;
if(mode == 2) // 计数器模式,显示计数
DisplayBuff[0] = count1/1000; //千位
DisplayBuff[1] = (count1-(count1/1000)*1000)/100; //百位
DisplayBuff[2] = (count1-(count1/100)*100)/10; //十位
DisplayBuff[3] = count1%10; //个位
if(mode==3) //显示时钟的秒,
DisplayBuff[0] = 20; //第一位不显示
DisplayBuff[1] = 21; //第二位显示一个点
DisplayBuff[2] = sec/10;//显示秒的十位
DisplayBuff[3] = sec%10;//显示秒的个位
* z5 Q( ]% W4 z+ ~' h4 p" Q
4 J3 m& l' a( u7 q2 L& P: B% x
//键盘扫描子程序//
void keyscan()
if(!key0 && bKey0Pressed == 0) //检测到key0按下
keypress0 = 0;
bKey0Pressed = 1; //防止重入此判断
while(!key0); //如果没放开,就等下去
if(key0 && bKey0Pressed == 1) //检测到key0放开
bKey0Pressed = 0; //防止重入此判断
if (keypress0<120) //如果是短按
if(ucStatus == 0x02)
ucStatus = 0x00;
mode = 0; //时钟模式
t_adjust=0;
else if(ucStatus == 0x00)
ucStatus = 0x01;
mode = 1; //秒表模式
else if(ucStatus == 0x01)
ucStatus = 0x02;
mode = 2; //计数模式
else if(keypress0>200) //如果是长按
mode=3; //显示时钟的秒的模式
if(mode == 0) //进入时钟模式后
if(!key1 && (bKey1Pressed == 0))
{ keypress1 = 0;
bKey1Pressed = 1;
while(!key1);
- ^0 ]2 J! x5 [0 h& V
if(key1 && (bKey1Pressed == 1))
bKey1Pressed = 0;
if(keypress1 >= 200) //如果是长按
t_adjust++;
if(t_adjust==3)
t_adjust=0;
else if(keypress1 < 120)
switch (t_adjust)
) Z) Q2 Y, J, z) x
case 1:{ //调整分
min++;
sec = 0;
if(min == 60)
min = 0;
break;
case 2: { //调整时
hour ++ ;
sec = 0;
if(hour == 24)
hour = 0;
break;
default:break;
- w5 R) W: a, } ~" S0 ^ else if(mode == 1) //进入秒表模式
if(!key1 && bKey1Pressed == 0)
keypress1 = 0;
bKey1Pressed = 1;
while(!key1);
if(key1 && bKey1Pressed == 1)
bKey1Pressed = 0;
if(keypress1 < 120) //短按
if(flag1==0) { start=2;flag1=1;} //start=2代表秒表开始计时
else {start=0;flag1=0;} //start=0,秒表停止计时
else if(keypress1>200) //长按
start=1; //秒表清零
: E! T9 V7 F# t6 ~ }
! f6 v8 g Y9 h5 z) I$ u
, `) a6 F1 R2 _9 y. ]# E X2 O ovoid timer() //秒表子程序
if(mode==1) //进入秒表模式才执行
if(start==1) //清零
ms = 0;
s = 0;
ss = 0;
mcount=0;
if(start==2) //秒表开始计时
if(mcount==20) //20*5ms=0.1s
mcount=0;
ms++;
if(ms == 10) // 10*0.1s=1s,s++
{ms = 0;
s ++;
if(s == 100) //100s
{s = 0;
ss ++;
if(ss == 10)
{ss = 0;
s = 0;
ms = 0;
if (start==0);//秒表停止
/ R" _" M$ V' |# I}
void it0(void) interrupt 0 using 1 //外部中断0 服务程序
if(mode==2) //只有在计数模式才执行
count1++; //每响应一次,计数加一
if(count1==10000) //超出四位时,不能再加
count1 =9999;
void it2(void) interrupt 2 using 2 //外部中断0 服务程序
if(count1!=0)
$ n1 h5 ~, D3 | c- k9 W8 _
' y H7 n; O+ ^7 ~…………限于本文篇幅 余下代码请从论坛下载附件…………
