查看: 333|回复: 2
发个16X16点阵+原理图+源程序
发表于 2018-12-29 06:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
发个16X16点阵+原理图+源程序. M% q& t; J  R6 L) Z
3 t9 B! j# U8 ?* M; T; n
& G1 u2 n% ^8 N4 W16X16点阵动态显示32个字,文字内容可以增加,修改,可以用论坛里面的字模提取软件,修改其他文字,显示效果:卷帘出,卷帘入,上滚屏,左跑马。大家一起学习,进步!
- B9 d$ p7 c+ q, X# S' j3 H  X
7 ?$ X4 N/ K8 _5 r8 E原理图:
( g1 R- H4 V! U' _ & R% ]; i' L, t7 e
! D) F, R7 g0 G单片机源程序:
$ g+ p, m4 Y3 A8 O9 X8 O% e1 D) `
  \) U/ O$ t$ p6 e16×16点阵LED显示屏程序6 N5 X  L/ h" q! `( L' ]$ I; d
mcu AT89C51  XAL 24MHz        12MHZ/晶振频率不同、刷新率也不同、供参考。! @# l/ a( a2 E1 B7 o
! _) V$ T% m! |! u9 g8 C  P--------------------------------------*/
1 E$ U+ T1 y( X#include
1 O  O) V# P3 f#define BLKN 2       //列锁存器数% q" E7 N. H2 k) o
sbit G = 0x97;       //P1.7为显示允许控制信号端口) G) i' c+ T; X! L9 K4 h
sbit RCLK = 0x96;    //P1.6为输出锁存器时钟信号端
4 V7 q  y# F0 K3 b5 S: s2 Rsbit SCLR = 0x95;    //P1.5为移位寄存器清○端* V: o7 l8 `7 k% b2 O5 \9 k
void delay(unsigned int);       //延时函数. q9 L+ B8 u' O5 q+ X) y( A
unsigned char data dispram[32]; //显示缓存
0 E) M6 c/ a7 P) B# c% x' X/*--------------------------------------
, u! u! y, u3 r( z  主函数 void main(void)9 q; E. t/ P9 E) w; i  r
+ |: c3 F, n0 Dvoid main(void)+ T1 V" g, F. r5 R: L; U7 t
0 |; w; a1 p9 c% r  {. K0 D  T' o) runsigned char code Bmp[][32]={//字模表
+ ~* [. S+ N1 T% p; S3 |3 N{0xFF,0xFF,0x80,0x01,0xFD,0xFF,0xFD,0xFF,0xFD,0xEF,0xFC,0x07,0xFD,0xEF,0xFB,0xEF,
4 v$ X9 ~# I( c: p% y. E 0xFB,0xEF,0xFB,0xEF,0xF7,0xEF,0xF7,0xEF,0xEF,0xEF,0xDF,0x1F,0xBF,0xBF,0xFF,0xFF},/*"W",0*/! U5 S" x% T# p' V% w' d$ D
6 b3 a) P: Y. V+ ^/ y6 A
{0xFF,0xBF,0x07,0xAF,0xF7,0x77,0xB6,0x03,0xB7,0xFB,0xB7,0x77,0xB6,0xFB,0x83,0x7F,/ u2 c9 V  G5 R5 c) d9 G: p9 `6 l4 x: P
0xFB,0x03,0xEA,0x77,0xD9,0xAF,0x3B,0xDF,0xFB,0xAF,0xD6,0x71,0xE9,0xFB,0xFF,0xFF},/*"J",1*/
& \# B% f! q5 f1 j6 r. F3 c, T' t5 ?. L  f
{0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xC0,0x07,0xDE,0xF7,0xDE,0xF7,0xC0,0x07,0xDE,0xF7,5 m+ W( e; ~/ u$ \  k% @) F/ J  X' j
0xDE,0xF7,0xDE,0xF7,0xC0,0x07,0xDE,0xF7,0xFE,0xFD,0xFE,0xFD,0xFF,0x01,0xFF,0xFF},/*"?",2*/
( o' ~, A8 p& {$ d0 H- W- a
' {3 ^+ j4 d! w" a/ y{0xFF,0xFF,0xC0,0x0F,0xFF,0xDF,0xFF,0xBF,0xFF,0x7F,0xFE,0xFF,0xFE,0xFF,0xFE,0xFB,# T9 l* ?; A5 V1 T2 g% }
0x00,0x01,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFA,0xFF,0xFD,0xFF},/*"?",3*/. D/ I" k1 U+ m# A/ J/ H# J; d
/ T! H3 G( @1 J# a/ M, k{0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
: p- l* U$ ^5 u- y, H! i  [ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xCF,0xFF,0xCF,0xFF,0xEF,0xFF,0xDF,0xFF,0xFF,0xFF},/*",",4*/: Z  {  V" m9 ~: H: x+ `( i
( H- m2 @# w( M{0xEF,0xBF,0xEB,0xAF,0xDD,0x87,0x80,0xBB,0xBE,0xBB,0xC1,0xC3,0xDD,0xFF,0xC1,0xB3,8 l' V: d! V3 r. }& }+ K7 `4 p  g
0xDD,0x8F,0xC1,0xBB,0xDD,0xBB,0xD9,0xC3,0xD7,0x77,0xDB,0xBB,0xBB,0xBF,0xFF,0xFF},/*"?",5*/
3 }0 {  I) ^6 y% r- \
. F6 N/ S3 p1 @3 X% Z{0xDF,0xBF,0xEF,0xBF,0xEF,0xBF,0xF8,0x01,0x7B,0xBB,0xAB,0xBF,0xAB,0xBF,0xE8,0x07,
9 W, F/ L( c& o9 ]: ` 0xDA,0xF7,0xDB,0x6F,0x1B,0x6F,0xDB,0x9F,0xD7,0x9F,0xD7,0x68,0xCE,0xF1,0xD9,0xFB},/*"?",6*/2 U* k- v1 }# X. a# H* R
* M- P+ K$ |( t& t+ b( Y3 z{0xDB,0xFB,0xCB,0xFB,0xDB,0xDB,0xC0,0x5B,0xBB,0xDB,0xFB,0xDB,0x80,0x5B,0xFB,0xDB,3 n4 y0 d- {/ q+ D- Q
0xC0,0x5B,0xDB,0x5B,0xDB,0x5B,0xDB,0x5B,0xDB,0x7B,0xD8,0x7B,0xFA,0xEB,0xFB,0xF7},/*"制",7*/+ A# e, l7 z( r$ V$ _; E
; A  j& l  i: G! V3 f' J2 [, o{0xF7,0x7F,0xF3,0x7F,0xF6,0xFF,0xEC,0x01,0xED,0x7F,0xCB,0x77,0xAF,0x03,0x6F,0x7F,$ `3 A# C6 n) U7 T; @, m. a' W
0xEF,0x7F,0xEF,0x7B,0xEF,0x01,0xEF,0x7F,0xEF,0x7F,0xEF,0x7F,0xEF,0x7F,0xEF,0x7F},/*"作",8*/
; K- Y& @, F! D0 `1 q" y
$ A# g2 c. P4 R{0xFF,0xFF,0xFF,0xFF,0xFE,0x7F,0xF8,0x0F,0xE6,0x47,0xE6,0x47,0xE0,0x7F,0xF0,0x7F,$ o( l( p' i" B" W8 \! K
0xFC,0x1F,0xFE,0x07,0xE6,0x67,0xC2,0x63,0xE6,0x67,0xF0,0x1F,0xFE,0x7F,0xFF,0x7F},/*",",9*/) L) m- [, |$ s1 J$ x
+ [( G0 M% B- L, {( Q0 s0 O
{0xFF,0x7F,0xFF,0x7F,0x03,0x7F,0xFA,0x01,0x7A,0xFB,0xB5,0xB7,0xD7,0xBF,0xEF,0xBF,8 B8 Z( Z3 d0 s$ i& W
0xE7,0xBF,0xE7,0x9F,0xDB,0x5F,0xDB,0x6F,0xBE,0xE7,0x79,0xF1,0xC7,0xFB,0xFF,0xFF},/*"欢",10*/7 G6 h; f5 P) c3 ]) q% l! j
8 e1 J% q0 H6 _" s: z4 r
{0xBF,0xFF,0xDE,0x7F,0xC9,0x83,0xDB,0xBB,0xFB,0xBB,0xFB,0xBB,0x1B,0xBB,0xDB,0xBB,7 ~' N6 i& S. U. U" w! f
0xDA,0xBB,0xD9,0xAB,0xDB,0xB7,0xDF,0xBF,0xDF,0xBF,0xAF,0xFF,0x70,0x01,0xFF,0xFF},/*"迎",11*/7 D) ~/ n& X. S$ _* ?. h
. \# L6 u  ?; n8 L4 p
{0xFF,0xFF,0xFE,0x03,0x82,0xFB,0xFA,0xDB,0xBA,0xDB,0xBA,0xDB,0xD6,0xDB,0xEE,0xDB,: q+ U+ O, o4 j
0xD6,0xDB,0xDA,0xAB,0xB9,0xAF,0xBB,0x6F,0x7F,0x6D,0xFE,0xED,0xFD,0xF1,0xFB,0xFF},/*"观",12*/
4 w  n- _$ j3 w9 e* O6 k- n7 S1 |  ]
- l$ u2 i3 @9 Y{0xFF,0x07,0xC0,0xFF,0xFE,0xFF,0xC0,0x07,0xFD,0xFF,0x00,0x01,0xFB,0xFF,0xF0,0x0F,
% U4 ~; N& R9 V3 z3 Y 0xE7,0xEF,0x90,0x0F,0x77,0xEF,0xF0,0x0F,0xF7,0xEF,0xF7,0xEF,0xF0,0x0F,0xF7,0xEF},/*"看",13*/3 \, ]& P: C+ Y: Q8 {4 y
8 ~. j/ O3 H# o2 g3 E
{0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x0F,0xEF,0xF7,0xD9,0x9B,0xB9,0x9D,0xBF,0xFD,  m% _7 _' y; g4 G+ \
0xBF,0xFD,0xBE,0x7D,0xBC,0x3D,0xDE,0x7B,0xEF,0xF7,0xF0,0x0F,0xFF,0xFF,0xFF,0xFF},/*",",14*/0 {' I8 ?, o% A  {% D6 S6 P+ E
( P# a5 {1 |* y0 F- g4 T* \
{0xFE,0xF7,0xBD,0xF7,0xC8,0x77,0xDB,0x77,0xF8,0x01,0xFB,0x77,0x18,0x37,0xDB,0x57,7 K- X; G9 X* h9 j8 C1 ]2 W
0xD0,0x57,0xDE,0x77,0xDD,0x77,0xD5,0x77,0xCB,0x77,0xD7,0x77,0xED,0x57,0xFE,0xEF},/*"谢",15*/$ j. c" _6 g0 l, ^( e9 g
6 D- ^% V  K. d7 L9 O, v( X7 W{0xFE,0xF7,0xBD,0xF7,0xC8,0x77,0xDB,0x77,0xF8,0x01,0xFB,0x77,0x18,0x37,0xDB,0x57,
# K* ]; G$ d6 X2 ^* ]) q 0xD0,0x57,0xDE,0x77,0xDD,0x77,0xD5,0x77,0xCB,0x77,0xD7,0x77,0xED,0x57,0xFE,0xEF},/*"谢",16*/  d& v6 V1 b4 r2 D4 c: U
; m( J. z: }/ N0 s; M3 B  d& }
{0xFF,0xFF,0xFF,0xFF,0xFE,0xFF,0xFC,0x3F,0xFC,0x3F,0xFC,0x7F,0xFE,0x7F,0xFE,0x7F,2 R9 s) o% ^3 k4 d! j
0xFE,0x7F,0xFE,0x7F,0xFF,0xFF,0xFF,0xFF,0xFC,0x3F,0xFC,0x3F,0xFF,0xFF,0xFF,0xFF},/*"!",17*/
2 c, e, }! H3 [) C' H7 D, n1 H) n- \
{0xFE,0xFF,0xFE,0xFF,0xFD,0x7F,0xFD,0x7F,0xFD,0x7F,0xFB,0xBF,0x03,0x81,0xBF,0xFB,
% F% d; I8 P- E 0xCF,0xE7,0xF7,0xDF,0xF7,0xDF,0xEE,0x6F,0xE9,0xAF,0xE7,0xCF,0xDF,0xF7,0xFF,0xFF},/*"☆",18*/$ [0 |3 o0 n& U) s% n; Z
3 T; x* R! [" z. m{0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x0F,0xE7,0xE7,0xC7,0xF3,0x8F,0xF1,0x8F,0xF1,4 [# A. t1 Z: q9 F5 r* q
0x8F,0xF1,0x8F,0xF1,0x8C,0x71,0xC0,0x33,0xE3,0x87,0xF0,0x0F,0xFF,0xC3,0xFF,0xF7},  /*Q*/% [3 l! ]( W4 I6 ~% {+ A
, g" Y; I1 s# v: D  {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x0F,0xE7,0xE7,0xC7,0xF3,0x8F,0xF1,0x8F,0xF1,
! Y' S9 W+ N* `' [, w6 l& \  0x8F,0xF1,0x8F,0xF1,0x8C,0x71,0xC0,0x33,0xE3,0x87,0xF0,0x0F,0xFF,0xC3,0xFF,0xF7} , /*Q*/$ ^! ^* w+ c1 I
, O' K, N5 [, N* f1 V$ L
   {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xCF,0xFF,0x0F,0xFE,0x0F,0xFD,0x8F,0xF3,0x8F,
( W9 z! D1 f- L8 k5 t  0xE7,0x8F,0xCF,0x8F,0xC0,0x01,0xFF,0x8F,0xFF,0x8F,0xFC,0x01,0xFF,0xFF,0xFF,0xFF}, /*4*/1 j# p' O2 z9 k, \
" f% u( c. x0 w7 g4 y  {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x0F,0xE7,0xE7,0xC7,0xE3,0xC7,0xE3,0xFF,0xC7,
" y7 s: {9 b5 Z   0xFF,0x8F,0xFE,0x3F,0xF8,0xFF,0xF3,0xFB,0xC0,0x03,0xC0,0x03,0xFF,0xFF,0xFF,0xFF},/*2*/
! O2 T* d3 w- Z) R5 y& Z8 L5 q! ]2 Z+ V  R2 {2 `$ Y( W: w9 U
   {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x0F,0xE3,0xC7,0xC7,0xE3,0xC7,0xE3,0x87,0xE1,
. o, U: ^* \3 F    0x87,0xE1,0xC7,0xE3,0xC7,0xE3,0xC7,0xE3,0xE3,0xC7,0xF8,0x1F,0xFF,0xFF,0xFF,0xFF},/*0*/' P3 s* X, x% \/ Z$ `" Q
. [2 j2 k9 R' o* g  {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x0F,0xC7,0xE7,0xCF,0xE3,0x8F,0xE3,0x8F,0xE3,
3 k& `; _) _1 |+ _% {7 c/ ~   0xC7,0xC3,0xE0,0x23,0xFF,0xE3,0xE7,0xC7,0xC3,0x8F,0xE0,0x1F,0xFF,0xFF,0xFF,0xFF}, /*9*/
2 b1 y8 r' d& v* n5 N
7 O! g  \% S; K/ g2 M- L6 G$ Y   {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x01,0xC7,0xF3,0xCF,0xEF,0xFF,0xCF,0xFF,0x9F,' q4 c! Q2 t& a/ P. j" Y4 @
    0xFF,0x3F,0xFE,0x7F,0xFC,0x7F,0xFC,0x7F,0xFC,0x7F,0xFC,0x7F,0xFF,0xFF,0xFF,0xFF},/*7*/  p  a" L! f5 u! P! s' u7 [7 {
. P0 Q# o: `. r8 O# T# d' L  X        {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x0F,0xE7,0xE7,0xC7,0xE3,0xC7,0xE3,0xFF,0xC7,
$ p# i3 D; Q! y# [. {) {     0xFF,0x8F,0xFE,0x3F,0xF8,0xFF,0xF3,0xFB,0xC0,0x03,0xC0,0x03,0xFF,0xFF,0xFF,0xFF},  /*?*/
1 F% [4 _2 `) B* w7 d
  F& z$ r5 O( N$ O# r        {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x03,0xE7,0xFF,0xE7,0xFF,0xE7,0x3F,0xE0,0x07,  R5 w5 L$ P3 N) w
     0xE7,0xE3,0xFF,0xE3,0xEF,0xE3,0xC7,0xE3,0xC7,0xE7,0xF0,0x0F,0xFF,0xFF,0xFF,0xFF},/*8*/
9 X* R8 g2 `+ K' Y$ R1 E) v! G  F* ?, ~  ]0 l5 V/ t* M
         {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x0F,0xFE,0x0F,0xFD,0x8F,0xF3,0x8F,  F: d3 X# c& x' F- C3 `% W
      0xE7,0x8F,0xCF,0x8F,0xC0,0x01,0xFF,0x8F,0xFF,0x8F,0xFC,0x01,0xFF,0xFF,0xFF,0xFF}, /*?*/
8 `# p! [! \0 L& x- M1 E% V0 E! A/ f$ n  A
         {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x03,0xE7,0xFF,0xE7,0xFF,0xE7,0x3F,0xE0,0x07,) R1 l* q( d: e. x& ~
      0xE7,0xE3,0xFF,0xE3,0xEF,0xE3,0xC7,0xE3,0xC7,0xE7,0xF0,0x0F,0xFF,0xFF,0xFF,0xFF},  /*5*/9 @( Y- i4 W9 i- \" ~
9 f3 |0 U$ _( ^* O
           {0xFF,0xFF,0xFF,0xFF,0xF0,0x0F,0xEF,0xF7,0xDF,0xFB,0xBF,0xFD,0x63,0xC6,0x63,0xC6,
5 p" F/ ~( b! e3 i: }7 n        0x7F,0xFE,0x7E,0x7E,0x7E,0x7E,0x7B,0xDE,0xBC,0x3D,0xDF,0xFB,0xE0,0x07,0xFF,0xFF}1 W5 s3 Z% g2 v8 b" ^  O; p+ X
; B' U- U( v. V3 m; O% q0 p
. _0 S: i; Q: B1 \( G…………限于本文篇幅 余下代码请从论坛下载附件…………% B5 _1 G) \+ o  A8 ^6 @% F
游客,如果您要查看本帖隐藏内容请回复
, ~0 |6 F) `2 k  E
- W4 P) W; Q. X1 z6 `1 z
发表于 2019-1-30 15:33 | 只看该作者
看看楼主的原理图
GMT+8, 2025-8-20 13:39 , Processed in 0.125000 second(s), 26 queries , Gzip On.
