HOTFIX VERSION: 006; i$ v+ c, z6 f8 W8 d, O
===================================================================================================================================0 P/ y+ D9 l5 ]5 [. |; b
CCRID PRODUCT PRODUCTLEVEL2 TITLE Q% S. c4 h% }- M4 Q1 ^2 \: q
===================================================================================================================================( _! ]& ]+ j. ]. T9 F$ C) m7 ?3 }$ c+ H
745241 CONSTRAINT_M TECHFILE Importing a tcf file automatically enables On-Line DRC.
' r9 T5 {. l% d9 c: j752587 ALLEGRO_EDIT PLACEMENT Uppercase File name(XX.mdd) for Placement replicate update on Linux.
% ~) M" S; V3 L8 g3 r1 g753626 CONCEPT_HDL CORE newgenasym error while saving the hierarchical block symbol: k0 k2 e7 s7 O4 n2 x, H" `6 t
753894 CAPTURE OTHER Case sensitive version control S/W
1 ~: S1 y2 l# Y8 j% Q# ]$ g* k754487 RF_PCB OTHER Various asymmetrical clearance problems uncovered - calculation issues?
& g5 I4 z( T6 {4 p8 j8 E* e$ M758272 CONSTRAINT_M UI_FORMS Entering values on the Min/Max Propagation Delays worksheet hangs the application.
( ?% z- g" r; q' ^) }1 |, C: B* ]758911 PSPICE PROBE Pspice crashes while exporting probe data using our sample project" P0 y* t5 @% W5 I
759871 CAPTURE PROPERTY_EDITOR Save option in Right Mouse Click on property editor of nets doesn't saves all the changes.
8 z. t3 \0 Z0 t$ y; g759890 SPECCTRA ROUTE Specctra autorouter ignoring prerouted nets; T% s$ k: D, f$ w U
760067 ALLEGRO_EDIT SHAPE Dynamic Shape not getting filled on board with odd angle placement and routing
5 U8 T8 f: G4 j$ u8 k) Y$ u: r760284 CONCEPT_HDL CORE Update Sheet Variables turns of the grid
, r5 t$ V5 C/ Y3 [/ t/ E% C760480 MODEL_INTEGR OTHER Message open clipboard failed when trying to open the rename/reorder dialog in Model Integr
; F/ Y! e$ d8 h# V( y760667 ALLEGRO_EDIT PADS_IN The pads_in.exe translate incorrect drill shape from PADS 2005 ascii database.! P& O+ C* y) g9 [& ~+ w ], K0 @' c
760741 ALLEGRO_EDIT MENTOR mbs2brd does not work in 16.3 but works in 16.26 M1 p$ d& F- A! W" N$ E' b" q, H
760810 CONSTRAINT_M INTERACTIV Deleting Region Deletes NCCs
3 a2 a; d* P; E1 X761114 PSPICE PROBE Refresh issue in Display > Cursor window* z( J$ K* z/ Y# _. e- l
761180 ALLEGRO_EDIT DRC_CONSTR Via_at_smd not working for custom shaped padstacks.
& E. S. W& F' u761305 SPIF OTHER Allegro crash when seleting any of the Route - PCB Router - submenu items.
0 h, E* G0 M2 |761376 ALLEGRO_EDIT PAD_EDITOR Wizard_Template_Path is not considered for symbol template look-up ?
( O/ }8 |& C: W5 [ ?0 d# D761416 ALLEGRO_EDIT DATABASE Allegro crash on chaning the subclass for group of clines
( j0 ]) z( M* S% n$ @9 Q( m761492 ALLEGRO_EDIT SKILL about axlTransformObject function* X" x+ @& W: N
761518 F2B PACKAGERXL about mismatch library path between cds.lib and actual/ k( I0 K) q* Q& \# [0 o" W! |& i9 h
761737 ALLEGRO_EDIT OTHER Running Dbdoctor after executing Skill is giving symbol fit error for the .dra file
9 F. \9 g, G5 i) I/ S, `' Y) H: v762155 ALLEGRO_EDIT SYMBOL Updating a symbol changes the netname of the cline resulting in drcs.$ r" C+ ]' f6 R5 r. d' Q
762181 ALLEGRO_EDIT OTHER Allegro netrev crashes for long device name in PST* files- ~% x( K# I& o
762316 ALLEGRO_EDIT MANUFACT Allegro disappears on Adding dimensions for the symbol file
2 J6 }5 u: X& Z% [; G% ?762792 ALLEGRO_EDIT PADS_IN PADS_IN fails for SPB 16.3# m* d: }' ?1 u+ I! A
763108 ALLEGRO_EDIT SHAPE Z-copy shape create an error like VOID boundary may not cross itself1 H; j8 Y: F1 N' U; e
763134 SIG_INTEGRIT SIMULATION Bit 7 of a simulation is out of sync with rest of bus. It should be the same for all bus va$ W8 s7 T1 s4 D- @: t5 W0 `& ?
763149 CIS GEN_BOM CIS BOM in V16.3 is not correct if database has Quantity field and its value is 0./ Y, D2 [6 _8 n
763296 ALLEGRO_EDIT REFRESH The error was happened while doing the SUM
% j) k+ \2 O \7 ?" a763303 ALLEGRO_EDIT OTHER SMD Jumper has a problem while using the Add Jumper
; S% M9 u6 `. [6 e6 U4 Z; G763315 ALLEGRO_EDIT PADS_IN pads_in got error message WARNING ERROR(SPMHDB-205)
( t0 R1 \; c: ^! z: G2 K763354 ALLEGRO_EDIT PADS_IN Auto suppress redundant shape while using pads_in translator
7 h/ {# e+ q: F R2 m6 w) y763428 ALLEGRO_EDIT PADS_IN enhance pads_in.exe translate spacing and physical rule into Allegro.9 T; j7 H, Z7 p0 d4 h
763446 ALLEGRO_EDIT REPORTS missing fillet is reporting pad without drill
# ]; C7 d9 b! M2 F763448 ALLEGRO_EDIT DRC_CONSTR Performance advisor shows Cset as unused nets when it is assigned to Diff pairs or xnets.
+ ]: A8 `6 ]" @7 r763586 ALLEGRO_EDIT DATABASE Allegro rounds off the value after decimal in CM
) L' p0 K f6 z9 E- X764077 CONCEPT_HDL CHECKPLUS The output predicate in the Graphical environment is not always returning the pin object fo |
