这些警告是啥意思?5 r+ R2 [( z, W7 I
/ Q& B/ j# {- ]$ l6 a h------ Oversights/Warnings/Errors ------
) W* A: u9 d8 D; ?. \4 d8 F2 j1 A7 n# W$ T, q
% q: L" R& U" B9 U9 H
#1 WARNING(SPMHNI-192): Device/Symbol check warning detected.
8 z7 P' i/ h( e! |7 }* O
9 Y; Z* E2 }# \WARNING(SPMHNI-194): Symbol '7343P' for device 'CAP_SMD_POL_0_7343P_470UF' not found in PSMPATH or must be "dbdoctor"ed.2 N. E; o$ C& Y( B' L% q
# Z Q6 e2 D6 g6 u6 V#2 WARNING(SPMHNI-192): Device/Symbol check warning detected.
" N/ G" _( H F ~4 A1 x3 K4 b9 ^+ n/ I8 p% d) l2 t/ P& q( v
WARNING(SPMHNI-194): Symbol 'CAP_SMD_8MM' for device 'PCAP_CAP_SMD_8MM_150UF' not found in PSMPATH or must be "dbdoctor"ed.
/ C. S% e& C& U: A! Q& D+ ^0 u( m2 `9 o9 y+ f. s+ @
#3 WARNING(SPMHNI-192): Device/Symbol check warning detected.
$ u$ O0 F; r3 b$ H1 `
' }, x2 ~6 N) m: V C% AWARNING(SPMHNI-194): Symbol 'CAP_SMD_8MM' for device 'PCAP_CAP_SMD_8MM_100UF' not found in PSMPATH or must be "dbdoctor"ed.
/ s" N9 k# b; a) c6 B b
( R/ D9 M# H% X* F#4 WARNING(SPMHNI-192): Device/Symbol check warning detected.$ {3 B" D$ l; ~0 v% e$ ~& u
( p0 S. x3 o5 A6 U5 ZWARNING(SPMHNI-194): Symbol '0805' for device 'LED_0805_LED' not found in PSMPATH or must be "dbdoctor"ed.
, F1 M: J& U5 `( I. h$ V1 b3 M' r. B ?- ^" _1 k; B
#5 WARNING(SPMHNI-192): Device/Symbol check warning detected.+ Y/ x3 U6 T8 v9 S% j$ n
1 h9 D' V& o @- Y2 F
WARNING(SPMHNI-194): Symbol 'SOT-323' for device 'DIODE_DUAL_CK_AAJ_SOT-323_DUAL_' not found in PSMPATH or must be "dbdoctor"ed.
S- Z+ b5 y5 D/ h- _1 x5 i; H7 z/ M$ M4 }
#6 WARNING(SPMHNI-192): Device/Symbol check warning detected.8 Q h- ], V: z; V
L g. ]% b, iWARNING(SPMHNI-194): Symbol 'HDR2X1_100MIL' for device 'CON2_0_HDR2X1_100MIL_CON2_0' not found in PSMPATH or must be "dbdoctor"ed.
3 `- x/ N: Q4 M# k9 d+ ?1 d) A ^/ w( |1 j+ a7 T$ e1 t2 b/ F% N
#7 WARNING(SPMHNI-192): Device/Symbol check warning detected.
) {* J. K: q6 [2 z
6 {2 V% S% I9 H% \) n. f1 j) z# X1 bWARNING(SPMHNI-337): Unable to load symbol 'CONN_39_26_7108' for device 'CONN PCB 5X2-S_JTAG_HEAD_CONN_3': WARNING(SPMHUT-127): Could not find padstack 70S043_MODIFY.
9 `; ]. y2 ?( P L( Z4 c2 t% o due to ERROR(SPMHDB-274): Unable to load flash symbol THR090X070 (Check PSMPATH setting for this symbol).
. m8 D3 O5 A2 A+ T8 j, m8 o$ L' T C8 S' E9 l! ~8 m
#8 WARNING(SPMHNI-192): Device/Symbol check warning detected.; K# Y8 X& H# `9 Y5 G
6 L/ O5 o- X; q4 b# FWARNING(SPMHNI-337): Unable to load symbol 'CONN_39_26_7108' for device 'CONN PCB 5X2-S_JTAG_HEAD_CONN_1': WARNING(SPMHUT-127): Could not find padstack 70S043_MODIFY.: g R: _. r6 ?! ^6 Q: p. Z
due to ERROR(SPMHDB-274): Unable to load flash symbol THR090X070 (Check PSMPATH setting for this symbol).- ]. J4 Q( A" E6 u0 L! K
_2 n" @3 I+ E
#9 WARNING(SPMHNI-192): Device/Symbol check warning detected.6 u$ b3 m4 t5 \5 H1 ~
3 x+ S, S" |& J; E. YWARNING(SPMHNI-194): Symbol '0805' for device 'BEAD_FERRITE_SM_0_0805_BLM18PG1' not found in PSMPATH or must be "dbdoctor"ed.5 E7 {3 T( k, _. a, I$ a
) a7 [1 _) g1 l) O
#10 WARNING(SPMHNI-192): Device/Symbol check warning detected.
4 I8 w4 l* l7 b9 @1 {7 d
& n* q2 D- k* \- d) }4 [$ U9 sWARNING(SPMHNI-194): Symbol 'LGA-15X15-144P' for device 'LTM4616_JERRY_LGA-15X15-144P_LT' not found in PSMPATH or must be "dbdoctor"ed.$ P) L Q0 r5 g
- N- f. q9 t: b4 X+ a1 m
#11 WARNING(SPMHNI-192): Device/Symbol check warning detected.
0 O; q$ P+ R% W M5 t4 L2 R) b l3 e9 l" [
WARNING(SPMHNI-194): Symbol 'FBGA1152' for device 'ALTERA EP1AGX60EF1152' not found in PSMPATH or must be "dbdoctor"ed.3 K3 Y0 v- V9 a- H
5 c4 [& l6 U4 j; m5 o; M0 [: ^#12 WARNING(SPMHNI-192): Device/Symbol check warning detected.% @* E* k# n9 ~1 `3 i) z" g9 I+ b
; h( j+ X& W# g' R1 c+ k
WARNING(SPMHNI-194): Symbol 'LGA118' for device 'LTM4601_LGA118_LTM4601' not found in PSMPATH or must be "dbdoctor"ed. |
