我的外形是不规则的多边形,有非水平或垂直的线段和圆弧组成,现在出gerber时出以下警告。
1 \' R6 S8 g# K8 h: ~- J怎么解决呢?
7 S1 t, `6 I5 M1 ]! J1 w, I出警告的地方只有圆弧处。为什么呢?! r2 v* Q: @: e0 x v- D
================================================================# K* @ g1 C [' `6 o' o1 c1 K
PROCESSING FILM < Etch_TOP >' F, G8 q; }8 y* \ f
TO FILE < H:/cadence/PCB/PT1000KBV0.1/Etch_TOP.art > ...
' V( R, F2 @, r3 v================================================================+ M5 Q. q F# |0 a) H
1 x6 L O! V, x2 O4 Z2 j FILM PARAMETERS :
$ A4 B. T6 O6 ^ H+ M* e ---------------------------------------------------------3 }# t5 }0 b5 t7 F& }8 n
Undefined line width 0.6000
/ D0 Z: G0 n; T: b" ?: h Mirror code NONE) |! ^2 H X( z" q- G# j
Rotate angle NONE
0 s! m; S1 z2 C( D% b; S2 C Offset x: 0.0000" h$ q. k# }* c) p6 w H
Offset y: 0.0000
$ [; p ~, e* c5 u o Plot negative NO. I0 X/ b# F$ w/ d5 {* k
Suppress unconnected internal pads NO- y+ h* p2 Q. s" q( e
- K7 h3 ~7 p7 K0 R' k# Y WARNING: Arc segment with end points of" y; R: U& j% H" j
(0.242, 32.227) and (0.035 42.508) converted to a line.
/ r9 S) X! e- Y! T* U+ h Its center location (1800.494 73.565) is too large for
- g# J6 V4 Q u, I) g specified integer accuracy of 3 places.+ G8 ~9 C5 f8 u4 N7 h* P! U
( x/ R1 D% i# K0 n
WARNING: Arc segment with end points of/ @5 Z" i; P y1 n- [
(2.016, 44.596) and (14.989 44.546) converted to a line.
% |) G- S- b0 ~1 ]" M/ Z Its center location (25.999 4547.984) is too large for
- k' {+ V# J* K: g, \1 f! P- c specified integer accuracy of 3 places.
% l5 s* p1 F% {" q6 T4 B4 n2 _, w1 H7 M! R6 }' d. V
# H" ~2 o+ m8 i, S& s* W (20.008, 44.535) and (32.992 44.535) converted to a line.- Y, ?7 h0 v7 R& }3 p9 E
Its center location (26.500 4547.982) is too large for* o: Y" [, |2 e2 z# v5 Z0 P
specified integer accuracy of 3 places.! h+ x: e. D9 c Q+ ` |! z
' k) j/ c" ?4 v* I* K! O" V8 n+ [0 O WARNING: Arc segment with end points of6 v! w: [: R ]) u# }
(52.964, 42.508) and (52.758 32.227) converted to a line.8 p) j( `9 c$ U1 S
Its center location (-1747.497 73.583) is too large for
4 P9 v9 [9 P1 A9 u- Y% P specified integer accuracy of 3 places.
7 T. ]8 u0 v& h5 \$ k
4 J/ i* |3 t7 t; }% I4 G% @1 z& g
7 [4 C' n* r8 [
* m8 X2 ~, q& V APERTURES USED:
1 \- k2 C8 ]6 c! C! p8 Z ---------------------------------------------------------
' N! z! F2 s5 q4 i4 J TYPE SIZE/NAME ROT MIRROR MODE ( ]& | {5 @( M3 y$ p
---------------------------------------------------------0 X0 b9 c: t+ v( Z, j. h5 |
CIRCLE 0.12700 DARK
2 G" ]: s. r M/ \ CIRCLE 0.30480 DARK 6 d$ ]2 D% v, s3 e
CIRCLE 0.40000 DARK
0 j- A3 G- l0 I4 I* A* S+ { CIRCLE 0.50800 DARK ! H% q7 O* T6 r9 L1 P! X
CIRCLE 0.55880 DARK 5 `8 A6 N) w, P
CIRCLE 0.62700 DARK : F) Z# |1 G! m& d2 X
CIRCLE 1.01600 DARK
/ ?- j& i, k! w+ a. O% Y RECTANGLE 1.27000 x 1.27000 90.000 NO DARK ! d1 s* C, {& n! q& o* a. d3 [
RECTANGLE 1.42240 x 0.91440 0.000 NO DARK 0 \: T9 [2 T3 s8 z
OBLONG 2.00000 x 1.00000 0.000 NO DARK
, P* j8 \6 a% B1 \$ B/ T8 W* m
0 ]; [, a" z' b$ \$ r Etch_TOP created with warnings
* ]9 T C& ]+ y2 t" G |
