查看: 887|回复: 0
关于问题求助~
发表于 2011-8-20 11:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位大虾,allegro16.3点击NET logic出现:By defullt this command is disabled to prevent inab\dvertent logic changes .To enable use the environment editor select the logic calagory and enable the logic_edut_enabled variable.' J" J2 e! F2 E! E1 f
怎么样才能解决,谢谢!
GMT+8, 2025-7-19 13:24 , Processed in 0.109375 second(s), 24 queries , Gzip On.
