请教一下,出钻孔文件时怎么出矩形焊盘的文件?我这里出不来,出了一些警告:
3 Y7 ~% ?) e! z6 z- j7 {. M9 U Processing route path data ...
8 w' a* T. }7 {/ Y9 Y$ g/ @1 [" m1 v7 Y
6 ?1 o2 \' @# z5 e j WARNING: No route path data was found for processing., L- _; U( [4 p" k0 `1 O$ N
8 a( D* L- p3 n, k5 {) A-------------------------------------------------------------. D/ [6 h$ y: u1 l. k! s# H
* Q8 Q6 @+ d; V) {
Processing slot hole data ...6 y( h' D+ _" W9 Z+ g$ F3 F6 ]$ I
3 Q* W. r9 w' u/ Y
WARNING: Can't find NC Route bit file (ncroutebits.txt)!
5 T/ L) {. L# r+ g; y9 U Using T01 to route ALL route cuts.# @0 L/ b. g8 ?, x) {7 q
$ g$ A5 V. h. \: x# ` WARNING: No toolcode of a size smaller than 39.37 found for a RECTANGLE slot!
) l+ k( S! g$ ]- B N" Y% | Defaulting to T01 as toolname.
+ A3 ^% T( t) B2 S4 }6 A! R9 M
" q2 _1 t- k# G) A# _ WARNING: No toolcode of a size smaller than 39.37 found for a RECTANGLE slot!
" H" [( W( X1 m0 R% c! _1 q Defaulting to T01 as toolname.
2 F$ g, z6 g$ p8 W
) [$ y0 U* u8 {8 R* L* q, F: H WARNING: No toolcode of a size smaller than 39.37 found for a RECTANGLE slot!& y5 @4 b: B4 K1 Q. `
l' o! D t0 L4 i' b5 Q
# E$ _9 x7 E( d/ ?, y* t. A OVAL slots routed: 01 |$ `+ o/ B+ P9 n3 C
RECTANGLE slots routed: 3 |
