TA的每日心情 | 擦汗 2019-11-20 15:04 |
签到天数: 2 天 [LV.1]初来乍到
9 Z) j) P# z2 }, G! f6 `( N; m( E/ O. Q5 G& U) t; y! @% t
出现和的错误如下:9 `! b/ T! ]& L6 ^4 T- K* y9 l
; N T$ x' O V% h. T5 c7 v2 E{ Using PSTWRITER 16.5.0 p001Mar-22-2012 at 14:53:06 }1 P. t2 E ^. o6 k
# `, v& [- j5 _) G% B" z
#1 WARNING(ORCAP-36038): "No_connect" property on Pin "U5.37" ignored for U5: SCHEMATIC1, 05-SDRAM (106.68, 175.26). Connecting pin to net "VCC3.3V".5 `% z% r: o8 w3 z$ G- l, s) [
#2 WARNING(ORCAP-36006): Part Name "CONN SOCKET 34X2_SIP34X2_CONN SOCKET 34X2" is renamed to "CONN SOCKET 34X2_SIP34X2_CONN S".- k/ C* V* S; p2 {; l
#3 ERROR(ORCAP-36004): Conflicting values of part name found on different sections of "U1".
4 z; o. u! {0 YConflicting values: S3C2440B_BGA289_S3C2440B & S3C2440B_0_BGA289_S3C2440B : s+ }3 l7 ~" }
Property values of "Device","PCB FootPrint", "Class" and "Value" should be identical + q8 D* Q5 t2 q5 K5 v& [! i
on all sections of the part.
" o1 m. J5 ~; N+ N4 g! a: T#4 ERROR(ORCAP-36018): Aborting Netlisting... Please correct the above errors and retry.
! T1 P- R8 K7 O) H/ H在线等答案!! |
