本帖最后由 coyoo 于 2012-5-24 13:41 编辑 r7 k2 h1 Z: k( H5 @
Dandy_15 发表于 2012-5-24 12:16 ![]()
7 L) l+ I* T4 `我个有觉得回流到紫色平面后,最后还得回到Driver供电的负极,也就是这里的地,现在的问题是紫色平面与地 ...
! k+ Z; R! q$ I) a) E( U' Y% D8 m3 Z* j; s/ B
这个问题我咨询过时钟芯片厂家的工程师,他给出的回流路径应该是这样的:
7 b! W7 B% n% J1 I; x-3.3V-》+3.3V; 下面是他给我的部分回复:9 K: r' O' H0 W/ c) t
In a split power planes, there are moats between different planes and single-ended output 100MHz signals may have run through those moats, as shown below:( o5 x8 X9 Y8 Q( Q+ X
- m. r+ ?, X F; r
Because this 100MHz signal is single-ended, return current must take the path of least resistance and -3.3V plane right above it provides just that. & `4 i* G) a* Q Y/ j
, K* A( n8 y* w. k7 b3 y- F, a9 X8 N g. i# h
也即回路电流从-3.3V还有跨越到3.3V后再到地,我不理解的是为什么不是直接从-3.3V直接到地,非得要经过芯片的供电电源后再到地? |
