查看: 3077|回复: 19
个人快捷键,仅供参考
发表于 2013-5-9 15:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
# F1 is normally reserved by the system for Help so we don't use it
1 e3 b: R  U! Z% J( L: palias F2 placementedit; Z$ g9 L7 A6 X& G2 X3 M2 f" S
alias F3 etchedit
4 \# E/ }+ T* R8 [3 m" palias F4 generaledit% Y( }7 v8 [; V- g7 L
alias F5 redraw
$ B: F+ e6 |' ]  valias Esc done% L) l" u4 F) x4 F+ |& \  O0 D& m
alias F6 prmed8 I& |. l) |- ~
alias F7 enved
' l0 r7 r6 _/ ?alias F8 cmgr7 r9 y3 K+ v; b6 [# @4 R/ t% h
alias F9 cns cmmodes
5 x' `, i" ]" Z; f0 Y, d8 Ualias F10 status  I5 j$ g! a1 G! [% ]: m4 k+ U( c( f
alias F11 reports
" y, K/ I/ w7 y) ]8 r8 |$ xalias F12 grid toggle3 {2 C  v  m% a3 I
alias Home zoom fit! y$ E. d9 P/ k3 N
alias SF2 property edit
; a' d( H8 [: b, T! Yalias SF3 slide
* N/ r. Z- j: \# \+ I4 Falias SF4 show measure
8 N4 O& `: d/ O' malias SF5 copy
8 r1 @4 h% z( F& `5 E' _alias SF6 move * G0 U+ v0 O6 I- C
alias SF9 vertex
# W* J! u5 r, g) `5 J- m2 g9 falias SF10 save_as temp
- K. f. @3 ~/ i' G6 x6 r( Ialias SF11 zoom previous
6 Q! R1 f# `3 Q$ Z1 palias SF12 zoom world
* M: _6 Z" [. F3 V% X. |9 ]3 dalias CF2 next- d7 }& S% c2 x
alias CF5 color192& N0 N: P: _, ?4 q) ~8 Q' G
alias CF6 layer priority2 G0 E7 @0 e! g. J! y3 V& I
alias CSF5 status
' k% ]- j2 ]- ^8 h* M" Aalias ~N new
8 q+ e! |4 H) d2 z8 w# P- valias ~Q show element
- N$ P1 j# N* r! Nalias ~O open7 O1 ]1 u) z6 }9 D% P% z
alias ~S save3 m3 v' y! y, C) O+ T* `
alias ~D property edit2 J9 {5 B1 m2 Z3 _' b
alias ~A show measure
, I8 n. r& C: xalias ~W change width
0 f9 ~/ R+ W" s2 T+ ?* }/ {alias ~Z undo% o, |9 s, O  A5 ?
alias Page Up zoom in( [9 C8 v! @( r2 ]! s
alias Page Down zoom out
- C& }, O* c* L3 S1 a
* Z6 ~* l& ~* O4 F' G" O% V
  d; O  K3 w  Q) R5 G- H; y- O7 efunckey G subclass -+
. J- ]* ~% y  G- s$ U, r3 Sfunckey H subclass --, _. y; u, g9 `+ l% z
funckey 7 dehilight all4 D- Q* _3 j! \/ {$ _! y. z
funckey 8 hilight pick- k* z  w- z- m4 h' e" Q
funckey F add connect3 Q# L5 j9 V- {; K" R1 C/ C
funckey E slide- y6 x3 W9 B7 Z! y3 V
funckey R custom smooth
  n: p( q8 f- M+ s$ Kfunckey V next/ K5 d4 J) ]! k4 A. J4 M6 r
funckey N cancel
0 }) c. L( K8 A$ nfunckey Q angle 90% J. \' ?( N; M( ]9 P% J. Z
funckey B oops+ z5 T& t% V# F. _" m
funckey ZZ group5 O8 @% P2 P# o! W, h5 ^% y
funckey ZA complete' u" A* Q" S' s% Q
funckey WW move* c' t" E! K% G& O0 p( F% b
funckey WV replay movevia.scr! E7 l( y/ e3 s' _
funckey WS replay moveshapes.scr% y- q0 p4 g: T1 @' y
funckey WT replay movetext.scr' [3 q+ ]9 D8 {+ s& h0 S- G
funckey WC replay movesymbols.scr+ @+ s9 g1 q7 P% V# W
funckey SS spin: ~" f3 {- }$ U3 {0 M* @7 ^% L
funckey SA mirror! w1 h  e, z7 x( w" R, g* p! E
funckey SD shape add5 S4 O! N' S. Z) ^) a: b
funckey SR shape select
" [$ Q6 n  I( ^4 G$ Tfunckey SC shape change type' _% O+ ?2 i+ C/ _) H
funckey SE shape edit boundary' q& D$ v0 V/ X  H8 R: Y( g
funckey SB shape merge shapes
0 B9 ]2 D/ `$ I3 Wfunckey SV shape void element2 z' l( v' X* c
funckey A  replay via.scr1 K8 u* f3 V3 j+ Q9 c* k6 ]# O" C
funckey TT delay tune
5 }; ~6 X" `4 ^5 Vfunckey TR phase_tune
0 B. S- T3 y" o: @funckey DR replay delcline.scr$ I0 x! M) x2 ?" [, R
funckey DV replay delvia.scr
( w( }, K* Z- r7 V. p& h6 ]: mfunckey DC replay delclinesegs.scr
# A0 V: d+ m) K* D  r6 p$ u8 efunckey DS replay delshapes.scr
* {6 C/ v$ W. o$ U) mfunckey CS replay copyshapes.scr( U7 S2 }0 i. v% ^
funckey CV replay copyvia.scr
& K; [. N* M3 Q% wfunckey CT replay copytext.scr
; j7 c8 B: q, f$ O, Y( ~funckey CC zcopy shape- R. ]6 F3 \* h3 l9 ^$ N0 g
funckey CF copy
8 a) ^) o0 x) i: [: R% s# f2 Ffunckey L1 replay lt.scr* Z% u% L! L/ J) I5 J; F
funckey L2 replay lb.scr6 v9 t( Y& T4 c
funckey LL replay ltb.scr
! _  G: ^2 {$ ]$ P/ W1 ?, ]) F6 Kfunckey LDN rats net
. g! o5 @9 ~  l7 b7 Hfunckey LDC rats component
) d) e! Z6 I" z, g  nfunckey LBN unrats net
; M% D% r; }+ B. \funckey LBC unrats component
" H; U$ I0 c  B/ N$ I& Qfunckey g1 replay 01.scr, O6 v! h% R" Q+ s0 H/ \' N6 u
funckey g4 replay 02.scr3 n- B' Z! x" X4 o
funckey g5 replay 03.scr
, V4 ?8 q3 C! x/ ]+ e' Nfunckey 01 replay color1.scr4 ~5 W+ m5 E) @7 y/ p$ R: r2 h1 @
funckey 02 replay color2.scr
# C/ d8 X' u: q6 z" _# M6 {funckey 03 replay color3.scr
  b: [5 C# q. O9 p0 wfunckey 04 replay color4.scr
* w& S% l1 }" d$ Y8 w1 ofunckey 05 replay color5.scr1 n  N, [: i# z  `( Q9 {
funckey 06 replay color6.scr1 J2 T2 I/ n: l- G
funckey 07 replay color7.scr
! S1 J1 b" W/ w1 X3 m1 Xfunckey 08 replay color8.scr
. l7 X# U0 D2 P& |# ?4 O6 efunckey 09 replay color9.scr' {: e( m' @% X( Z3 C' N
funckey 10 replay color10.scr0 K% ^0 Q3 u. `' Q& }
funckey 11 replay color11.scr
# D! {( |9 `2 zfunckey 12 replay color12.scr0 ^* G3 A1 m* y8 p6 E! k' x
5 N( X' A% v2 y$ J+ @funckey 303 options acon_line_width 3
, Z; O# R( e9 j; n6 ?# Kfunckey 304 options acon_line_width 4/ b7 `9 G" o  `, H4 K0 x& e
funckey 305 options acon_line_width 5
0 Q. r8 e# \% t+ bfunckey 306 options acon_line_width 6% O: ]% ^8 h( G1 e
funckey 308 options acon_line_width 8
+ `5 a% B0 _( Yfunckey 310 options acon_line_width 10
- R: x' S6 U# G7 |. o! c0 c% i5 ofunckey 312 options acon_line_width 12
- d+ U8 e) h3 z& \6 X0 ?2 qfunckey 315 options acon_line_width 152 I& s) u$ w4 B# |$ E- ~- B
funckey 320 options acon_line_width 208 F1 g; w4 A' {9 w
funckey 325 options acon_line_width 25
) ^! g/ B9 t0 A- A4 R7 g; vfunckey 330 options acon_line_width 30, a) ?  D& x& Z9 S0 ]
funckey 340 options acon_line_width 40* |  N& c6 F4 U4 p7 h4 J: {
" M8 O; s. k( p/ [% Tfunckey PO replay po.scr
6 W2 @; g6 c% y! Jfunckey PP replay pp.scr
; J' D; S$ O+ T: X: Hfunckey OO replay oo.scr
7 o8 G* H( c5 S" E; mfunckey OP replay op.scr- h  |! N3 ~1 h! A3 y
膜拜ing!  发表于 2013-5-9 15:40
参与人数 1贡献 +2 收起 理由
billymc + 2 赞一个!
    2023-2-12 15:39
    推荐
    发表于 2013-11-13 11:39 | 只看该作者
    膜拜了,帮我解决了困扰我2天的问题,THS
    推荐
    发表于 2013-11-13 11:43 | 只看该作者
    我的快捷键改了N次,都没成功!
    发表于 2013-5-10 09:08 | 只看该作者
    scr文件没有,好多没用
    发表于 2013-5-10 10:10 | 只看该作者
    SCR文件得自己录吧
     楼主| 发表于 2013-5-10 11:16 | 只看该作者
    本帖最后由 shokwu 于 2013-5-10 11:21 编辑 ; k: W6 h% `# S3 u
    2 Z# \# e0 b' B( O, t
    SCR文件自已录,只提供一个思路,这个东西没有一定的标准。比如:dxf in dxf out idf in idf out,这些命令本来就很简单,又不常用,就没有必要设了。直接输命令就行了。Po关闭铜皮的显示,PP打开。OO OP是改变静态铜皮的显示方试(16.5-16.6适用。)
    发表于 2013-5-10 14:16 | 只看该作者
    个人认为这个快捷键不方便没有我的方便,呵呵,仅供参考勿喷!1 u4 O# `% f( p: X0 A% P) u$ P
    1:左下角打VIA
    ' k) q7 K5 @  T$ X2:属性$ t4 N3 z. H: n
    3:右下角打VIA
    0 |; i5 T) _5 T& `. F1 _7 q4 L9 U4:show element+ Z: m! d# s$ H5 h  r; V1 j
    5:sawp components
    ( `2 f8 l7 p. A! v6:swap gate
    5 n8 T7 w  O+ a# m( W( E2 R7:左上角打VIA  G' m, o+ d0 O6 E. w
    8:vertext:加端点
    ( @% R) H  V* j. P. k4 p8 W& R9:右上角打VIA
    . ^/ L" E  C4 {& z+ D, k0 EF2:放大:F3:缩小/ P" Y% `8 G8 n
    F4:回到前一界面, u0 d% }# J& ~- E  F4 Z$ y6 ]: x" E" F
    F5:换层面% a; G4 |; I4 k' f  g
    F6:手动加测试点; {% m! u2 ?# V/ ~! _; e' h
    F7:Grid0.1:0.1- V- f9 G. p7 }. v& Y, q
    F8:Grid1:1
    # ^) H% B7 n1 HF9:Grid5:5
    . q) s- ~3 a- _; d, C- oF10:Grid10:10
    发表于 2013-5-10 14:17 | 只看该作者
    不一一列举了,呵呵
     楼主| 发表于 2013-5-10 14:33 | 只看该作者
    xcq521122524 发表于 2013-5-10 14:16 ) E" E0 z% [" t9 c  Z
    个人认为这个快捷键不方便没有我的方便,呵呵,仅供参考勿喷!" g5 D8 R% o* I
    1:左下角打VIA. P7 z4 E$ j" j6 h
    2:属性
    * ?; W" N" G) M; F: |, i呵呵,想要啥就设啥。这个没有统一。自已学得爽就行了。
    . I1 p$ P) r% N6 E" j6 f: ?
    * z; O, e, j, P; T% g; l* q( P3 B
    funckey MA artwork 1 h* u8 r* }  p% z4 g: r! _
    funckey MD nctape_full
    " w6 n3 D& ~! u- z% o% jfunckey MR ncroute, ~+ Y1 ~9 k7 \5 b$ P5 M. H
    funckey ML ncdrill legend
    1 G( m6 p* q- d7 P9 w$ ^( Qfunckey MN ncdrill customization
    5 n* t/ k* b- a$ Y$ z. C$ ]/ Ofunckey MC dbdoctor) K, v4 H( {  ]$ G6 m! s) i
    发表于 2013-5-30 22:40 | 只看该作者
    快捷方式不错啊
    发表于 2013-5-31 14:01 | 只看该作者
    还是根据个人习惯来比较好。
    发表于 2013-6-17 08:15 | 只看该作者
    看来PADS 是随你所用哦! O$ h0 _  x2 ^- K! Z5 w
    发表于 2013-6-17 13:23 | 只看该作者
    不错!
    发表于 2013-6-17 17:59 | 只看该作者
    快捷键只有用习惯了就行。
    13#
    发表于 2013-6-18 09:02 | 只看该作者
    快捷键都看个人,所以每次要是用别人电脑就小操作一下就没那么方便了。要么将就着用要么弄个临时SCR文件。
    14#
    发表于 2013-7-25 11:22 | 只看该作者
    scr后缀指的是什么啊???
    15#
    发表于 2013-7-27 11:08 | 只看该作者
    竟然用N来作Cancel, 为什么不用 Esc ?
    GMT+8, 2025-9-7 09:10 , Processed in 0.140625 second(s), 29 queries , Gzip On.
